Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Screen Gone My screen went blank and has not returned. I have checked all inputs and they seem fine. I have switched from HDMI 1 to HDMI 2, no luck. Volume and signal seem fine, I simply have no picture (on ANY input). The screen is back lit but is essntiall black. There are no shadows or anything. It's as if the video feeddies but everything else works.
  • 7 more comments
  • Norcodad77 Oct 25, 2008
    I cannot "reset" to factory settings as I cannot see the screen or operate the menu to do so. Also, all power settings are working. Let me clarify. I'm listening to CNN right now. It's just that there is nothing, I mean nothing coming through the screen output but backlighting. There is no picture. Menu controls even do not appear.
    Unplugging did nothing. or did having it unplugged and off all niht last night. It's only on now because I need my news fix! At least I can listen!
    The stand by light works and flashes three times before turning on...just as it always has. Honestly, wth the exception of no picture signal, just a black (but lit) screen, the T.V. works EXACTLY as it did before. I can listen to the t.v. as if it were working fine. In fact, when it stopped working I didn't notice. My back was to the t.v. the sound was working and when I turned around, there was no picture.
    Actually, the backlight works just fine. There's no video feed from the T.V. Not the receiver, but the T.V. itself. That's why I can't even see the control graphics.
    Am I totally hosed here? The warranty just expired too.
    Tuner box has been un plugged before. It is again, but this seems as if what I'm dealing wit here is a dead video card...as in it simply died. Where do I go to fix that nd what kind of cost am I looking at?
    I am at my wit's end here and your (and that of the expert who mentioned the video card) opinion makes the most (and most unfortunate) sense.
    How can I go about getting this repaired?
  • heyzues May 09, 2009
    i like to play my xbox and after about 30-45 minutes of playing the tv turns black. but i can still hear my xbox and all the sound, just no picture. i have found that if i leave my tv off for about 15-20 minutes, when i turn the tv back on, the picture works. but then the tv's picture shuts down and i have to repeat the process.
  • Anonymous Mar 21, 2014
    there is a faint illumination but no picture just a "lit up" black screen, audio seems fine
Hey! did you find the solution? (i have the same problem) if you find it, let me know please!!!
Posted on Jun 27, 2009
    Scholar:
  • 85 Answers
Dear
May be some technical default in ur TV
So u contact Toshiba Costumer Care At 800-631-3811  Num.
or Contact online them to following link:-
http://www.tacp.toshiba.com/customersupport/contact.asp
U should tell or write ur brief prob. to them. They will guide u to solve ur prob.
Thanx
Posted on Oct 25, 2008
  • 320 Answers
It sounds as though the backlight has failed or shutdown for some reason. You can confirm this by putting a flashlight against the screen and seeing if there is any picture visible. The fact that no OSD or menu is visible leads me to think that you have no backlight. However, if you can see that screen is lit, then don't waste you time trying this. Hope this helps.
  • 2 more comments
  • Any Guy
    Any Guy Oct 25, 2008
    So you DO have a backlight but no picture. With no OSD or menu showing, the only things left are the video process board or the panel (and the TCON board). The TCON board is the address board for the panel which tells which pixels to turn on. On some sets, the TCON board is supplied with the panel, on others it can be replaced separately. Has to be one of the two. Unfortunately you will need a technician to narrow it down for you. Sorry I couldn't be of further assistance.
  • Any Guy
    Here are my suggestions for finding service. Choose a servicer that is au authorized provider for Toshiba products. Avoid the places the promise free estimates as they tend to get their money from you in other ways. I wouldn't suggest you just buy a video board and try and put it in yourself; if it's the panel that's failed, you'll be stuck with a video board, since most places won't take back parts that have been used. If you have further questions, please feel free to ask. I'm here to help in any way that I can.
  • Any Guy
    Bappa,
    May I ask why you are suggesting polaroid parts for a Toshiba unit?
    Norcodad,
    Since the warranty has just expired, I would not hesitate to contact Toshiba to see if they will offer some type of accommodation on the repair. Many times, the manufacturer will offer to pay parts, labor or some portion thereof. Hope this helps.
  • Any Guy
    You can start here:
    http://www.csd.toshiba.com/cgi-bin/tais/...
    to loacte a servicer in your area. I'm assuming you're in the US, pardon me if I'm wrong
  • 899 Answers
You neeed to try to reset hdmi setting , turn off the tv for a min. , turn back on tv then turn back hdmi settings , if resetting the hdmi doesn't work un hook all connected cables , turn off tv and unplug from the wall , leave unplugged for a half hour at least , then try again. if all this don't work then a component inside is failing and will need testing or the video board replaced
electech
  • 3 more comments
  • jason Oct 25, 2008
    if theres a reset button on the back off the set press it , if not then you have to unplug all cables shut down the tv unplug it for a while , if that don't work then it needs repair
    try unpluging the tuner box, have you tried that also?
    are you using cable , sat , or other source for tv channles?
    unplug that .
    any other video inputs on the tv may also be causing no video , make sure nothing is hooked up then do a reset of tv , if it still will not give you video , then it for sure needs repair
    hope you aren't expecting me to help you now
    Brigadier General:
  • 3,614 Answers
i would like to know what is the tv model, and did you hear any sound coming from the tv. and the led lights status on the front panel of the tv.
let me know
    Scholar:
  • 136 Answers
Remove all the connections and wait for a minute and then 1 by 1 replug all the connections and then try.
some times this helps.
    Genius:
  • 1,913 Answers
Reset your diaplsy setting s to factory defaults.
also check your power supply waltage and earthing properly working
    Master:
  • 505 Answers
The TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
As already pointed by the other expert, from description, the digital processing board. can be cause for the problem as there is no video.
However all the following parts can be involved.
Parts involved can be
Polaroid digital processing board.
Polaroid replacement ballast.
Polaroid Replacement LCD controller
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
Radio screen showing blank lines across it
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 09, 2017 | Televison & Video
Sony Bravia flat screen TV when turned on has black screen. Green light on the bottom is lite up, electric plug is plugged into house socket, no picture only black screen.
If audio is OK, the fault is with its backlight section. If audio too is absent, the fault is with its digital main board. If you wish to get more details visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Jan 08, 2017 | Sony Televison & Video
Vertical lines on my plasma tv
Jan 08, 2017 | Samsung Televison & Video
How do i fix black spots on my LG plasma tv. model 50pj350ub
Jan 08, 2017 | LG 50PJ350 50 HDTVReady Plasma TV
How do i fix my elonex tv
switch off.wait for 5 mins.
press & hold power button till it turns on then off.
ifno luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
May 04, 2014 | Televison & Video
No hdmi audio
Go into audio menu and reset audio input to HDMI.
Apr 21, 2014 | Televison & Video
50" LG Plasma Screen TV does not have any sound or activity on the screen.
input correct ? eg:HDMI 1 USE MANUAL TO GET INTO SETUP MODE.go through all settings.check the contrast and brightness buttons n the TV if any on back or top.
Apr 15, 2013 | Televison & Video
I have a bell satellite reciever, I am trying to hook up a second tv to the hdmi output, I hooked up a hdmi splitter! but it does not seem to work. I get a picture on only one tv and no sound. when I...
NO YOURE NOT WASTING YOURE TIME YOU JUST NEED TO PUT THE MAIN CABLE FROM THE STAELLITE INTO TO WHERE IT SAYS IN AND THE OTHERS CABLES IN WHERE IT SAYS OUT AND OUT AGAIN
Apr 21, 2011 | Toshiba 26HF85 26 in. Television
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
742 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
