Question about Casio FX9750GII Graphic Calculator
How to use casio fx-9750gII for sample variance and standard deviation grouped data
Need to use calculator to solve data problems with class ie; 100-199 200-299.....etc
3 Suggested Answers
SOURCE: how to do standard deviation on a casio fx-300 MS
http://www.geocities.com/calculatorhelp/casiofx300ms.htm
Posted on May 14, 2009
SOURCE: how do you calculate sample variance...
http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf Check page 26
Posted on Feb 21, 2011
How to calculate the standard deviation? casio power graphic fx-7400G Plus
Here are the capabilities of the Casio calculators.
The screen captures may not look like ones taken from the FX-7400G
plus display but the instructions are accurate.
In stat enter the values in List1 and the frequencies in List2 (if doing paired variable statistics)
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-variable stats or regressions.
Use you knowledge of sample standard deviations and
population standard deviation to select which is relevant to your case.
They are given by xsigma-n and xSigma n-1
Aug 15, 2011 | Casio FX-7400G Plus Calculator
How can i use casio 991ms to solve all statistics questions
first off you want you calculator in SD (standard deviation) mode to do this hit mode twice and then 1.
next it is good practice to start off by clearing the memory to do this hit shift, CLR,1 and then = this will clear statistical memory
to enter values into your data set , you enter the value, then press the DT (M+) button. (note: pressing DT repeatedly will impute the same value multiple times)
once you have finished pluging in your numbers your calculator can give you statistical information about the data set.
hitting shift then 1(S-SUM) gives you three options: 1 the sum of the squares of each value 2 the sum of each value 3 the number of terms in the data set hitting shift then 2 (S-VAR) gives you three more options 1 x bar (the mean) 2 x sigma n (the population standard deviation) 3 x sigma n-1 (the sample standard deviation)
you can use these tools to solve alot of statistical problems i hope this helped
Source: http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf page 28 of he pdf
Dec 01, 2010 | Casio FX-300MSTP Scientific Calculator
How do I get the variance, the standard deviation, and the sample standard deviation in a casio FX-115Es.. Thank you
The variance is the square of the standard variation
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Oct 27, 2010 | Casio FX-115ES Scientific Calculator
How can i do standard deviation on my calculator
Click on the Mode button twice until you see “SD”. Select 1. This puts the calculator in Statistics Mode. image001.gif Enter the first number, 1.
image001.gif Hit the M+. (n= 1 will appear in the window)
image001.gif Enter the second number, 1.
image001.gif Hit the M+ key. (n=2 will appear in the window)
image001.gif . . . . .
image001.gif Enter the last number, 7.
image001.gif Hit the M+ key. (n=7 will appear in the window)
image001.gif Hit shift, 2. (This invokes the S-Var option.)
image001.gif Hit 1 for the sample mean. Hit Enter.
image001.gif Hit 3 for the sample standard deviation that we will use in class. Hit Enter.
May 19, 2010 | Casio FX-115ES Scientific Calculator
How do I use the standard deviation function?
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Apr 30, 2010 | Casio FX-260 Calculator
How to use that standard deviation on the Casio fx-260solar calculator
Apr 27, 2010 | Casio FX-260 Calculator
Calculate Variance on Casio FX-83ES Calculator
I am happy that you found my solution helpful and even flattered that you copied it in this thread. By doing this, you gave me the opportunity to discover an error in my post. In fact, the calculator does provide a column for the frequency. If you enter nothing in the frequency column, all data items will have their frequency set to 1, by default.
Back to the current subject: How to get the variance (the square of the standard deviation).
When you finish entering your data:
  1. Press the [AC] button to exit the data editor.
  2. Press [****][STAT].
  3. Press [5:Var] to open the statistical result selection screen.
  4. Press [3: xSigma_n] or [4:xSigma_n -1] depending on what you are interested in (population or sample) standard deviation.
  5. The screen echoes the symbol for the value selected (the value displayed on the bottom line may be 0 or an old value from a previous calculation: it is not the value you have just calculated).
  6. Press [=] to display the current value of the SD chosen.
  7. By doing this you are in fact storing it it answer memory.
  8. All you have to do now is to raise it to power 2 by pressing the [x^2] key ( the one above the [HYP] key).
  9. The calculator will display Ans^2.
  10. Press [=] to display the value of the variance.
If you are not interested in the value of the standard deviation, but just want the variance, follow the foregoing procedure until step #5.
While the symbol xSigma_n or xSigma_n-1 is still displayed with the blinking cursor to its right, press the [x^2] key above the [HYP] key. The screen displays say xSigma_n ^2. Press [=] to calculate the variance.
As my motto says, I am always happy to help, but happier still when people show true appreciation.
Hope it helps.
Dec 11, 2009 | Casio fx-300ES Calculator
How to do standard deviation on a casio fx-300 MS
Mar 11, 2009 | Casio FX-300MS Calculator
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Casio FX9750GII Graphic Calculator Logo
2,042 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
