Question about Maytag Kitchen Ranges
Model MGR7662XX is not heating past 100 degrees and now will not unlock on the touchpad
GodBlessU
  • 3513 Answers
SOURCE: oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Posted on Sep 09, 2009
  • 9 Answers
SOURCE: the oven will not heat past 100 degrees on the
repace the oven sensor
Posted on Jul 21, 2010
heatman101
  • 43501 Answers
SOURCE: It turns on but won't
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 27, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a maytag MER6772 electric rage and the
The board cannot function if the sensor is bad. You should always check a sensor first.themobilian_898.jpgthemobilian_899.jpgthemobilian_900.jpg
Use this chart to check the sensor.
This video shows how to check:
I have some manuals and error codes posted HERE
Posted on Jan 15, 2011
Daniel S
  • 4323 Answers
SOURCE: My Maytag Gemini double oven gas...........the
Hi
This issue seems to be with the gas inlet valve or the igniter itself that is bad. Gas Valve has a bi-metal that open when a certain amount of current flows through it to heat it up. Make sure that the glow bar is not cracked. Faulty igniters can allow correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 18, 2011
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
What's an f1 and f2 code mean???
The F1 code means that a button on the touchpad is stuck
The F2 means that the oven tempature was at least 100 degrees over what the temp it was set to was
the F1 will come sometimes if the ribbon connection on the touchpad doesnt fit well into the control board and other times it comes because the touchpad is defective
the F2 comes up because the control has measures the temp and thinks that when it set as lets say fro instiance 350 degrees the control thinks the temp ahs reached 450 degrees(100 plus over) typically the thing wrong when the F2 comes up is the oven sensor at room temp to be between 1060-1100 ohms
However if you are getting both error codes at the same time the only thing common to both is the oven control and if both at the same time i suspect the control is the problem
GENE
Sep 06, 2011 | Whirlpool Kitchen Ranges
It turns on but won't heat past 100 degrees.
heatman101
Sep 26, 2010 | GE Profile JS968 Electric Kitchen Range
Oven does not heat over 100 degrees
Hi
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
After cleaning the top half oven with a self-clean cycle the oven will not pre heat past 100 degrees. The bottom oven will heat. What might be causing the top to malfunction? The serial number is...
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Aug 21, 2009 | Electrolux Ovens
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
Maytag MER5870 Electric Kitchen Range
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
Sep 22, 2008 | Maytag MER5870 Electric Kitchen Range
Kitchen Ranges Logo
99 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
