Fta viewsat 9000hd rebooting/locking up and i tried so many times with serial cable to download with factory bin file, but still the same problem. when i turn on receiver says:starting....,says init,>boot> on>time 00:00am cycle again and again, even i use the remote control at all. please help me out. thanks, tony
  • johndoe60 Nov 18, 2008
    reboot only when on a hd channel
  • 6 Answers
SOURCE: Reset the remote control?
I have the same amp. Try leaving the batteries our for a while like more than a day. Also if you can join a wire from each battery terminal to the others for a while. That will short out the remote and 0 it. This should cure your problem. I have had to redo the remote many times. Also while the remote is out press all the buttons in as many as your can for a while.
Posted on Sep 01, 2007
SOURCE: Remote locked
I had the same thing happen. This fixed it...
1. Press master power switch OFF
2. Hold down Speaker A & B buttons simultaneously then press master power switch
Display will flash at 1 second intervals denoting that the microprocessor has reset.
3. Release Speaker A & B buttons
Remote should now work.
Posted on Oct 26, 2007
  • 9 Answers
SOURCE: how to fix viewsat 6100
www.ftabins.net
Posted on Jan 06, 2008
krihard
  • 407 Answers
SOURCE: FTA - View Satellite Ultra receiver powered off during BIN loading
plz chack your conection perporly
Posted on Jan 28, 2008
SOURCE: fta viewsat extreme dead.
vs2000 ultra if you have a reciever that has only dashes on the display it is a quick fix.... ftaindex fail fix with loader 2.....if your box has nothing on display but the spdif lite comes on in the back then you need a tsop replaced i am currently researching a fix while the chip is still on the board...i amvery close
Posted on Feb 23, 2008
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Missing alot of channels
Try updating your FTA receiver with the latest files/keys.
May 19, 2009 | Ultra (31624) (ULT31624)
Viewsat platinum lite 4 line, is dead.
Those four lines are usually hardware related.
When you say you tried to download the latest "fix".
What "fix" are you talking about?
Mar 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Viewsat ultra
The viewsat ultra is not hd you cannot download a hd file on there .You need to install a factory bin then new fix on file viewsat ultra not hd.
Jul 11, 2008 | RCA DISH Network(r) 311 Satellite System
Need step by step guidance to fix my viewsat ultra 2000
user guides fta files bin files and factory files are all free to download never pay for a fix! go to tvkeyz.com and join for free all the help u need is there ! if this helps please vote for me
Feb 08, 2008 | Yamaha HTR-5730 Receiver
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Fta viewsat extreme dead.
I am using viewsat extreme 2000. After downloading the new program PC-STB. Front panel power has gone. Only rear light on. All view has gone.
Would you please send me by email, how can I solve this problem? I shall be grateful if you please reply.
Thank you.
-Rajesh
rkb@295.ca
Dec 11, 2007 | Audio Players & Recorders
Viewsat ultra 2000 fta sat. receiver
I have sat ultra 2000 have some file store in my disk when I download to receiver by mistake I klick the file fix. I put the power off and remove my cable put the power on I have some problem that Receiver constantly on and off and I try to download the file I can't because the power does not stay and there is no line or 0 digit please help me
Thx
Robin
Nov 26, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
83 people viewed this question
 Grubhead
Grubhead
