Question about Cell Phones
Have USB Connect 881. Looking for anttena to hook up to 881 as unit living in has metal sides and roof so need somthing to receive signal that is external.
  • Jesse C Smith Jr
    Jesse C Smith Jr May 25, 2009
    I have a metal roof and need to know what external antenna would be best. I have been disappointed with AT&T's Broadband.
    Brigadier General:
  • 7,752 Answers
Try an antenna booster
Posted on Oct 25, 2008
I use the Denon avr 881 receiver I just realized that it loses sound for jus a second or two then returns like nothing happend also when the sound leaves the signal: lock light blinks thanks please help.
lock light blink looks like input signal gone intermittently, I guess it maybe HDMI version compailable problem, suggest to manage to find new firmware to improve it.
Mar 28, 2011 | Denon AVR-881 5.1 Channels Receiver
Brand new radio that the songs cut in and out all the time. Haved tried two different anttenas both do the same! Any sugestions
Your antenna needs to face a Northwest position to achieve a good signal if it is used for home use. Also any type of blockage such as trees,buildings,hills..etc will cause this while using it in a vehicle. Roof racks and vehicle compasses will also cause this if the antenna is mounted too close to either of them.
Sep 19, 2010 | Sirius Starmate ST2 Satellite Radio...
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    How many pc can i connect with usb connect 881
    At least three--that's what I do. I have the 881 docked in a Cradlepoint router with a wireless access point. The 881 provides internet access to all. Been doing it for almost 3 years--no complaints.
    May 10, 2010 | AT&T USBConnect 881 Cellular Phone
    Changing cord on very old maytag dryer
    Looking at the cord, connect the center ring to the center terminal on the terminal block. Now connect the remaining two, one on each side.
    Apr 06, 2009 | Dryers
    Radio shack pro-95 scanner
    Radio Shack scanners are not as sensitive as others, but the problem may be your location, especially if you're in a valley with mountains between you & the town that you're trying to receive, or if you have aluminum siding on your home, as metal blocks radio signals.
    If either of these is the case, the best solution might be to erect a scanner antenna on your roof or the highest place possible (above metal siding) & connect its cable to your scanner.
    Sep 21, 2008 | Radio Shack Pro-95 Handheld Scanner
    My pc is a new phillips freevents with windows vista. i seem to be having trouble tuning my digital stations in.I have connect the anttena to the back of the pc and tunned some stations in it seems to only...
    It sounds like the problem can only be either the card or the antenna. the Media player only plays the received signal from the card. perhaps, the antenna position is too low or surrounded by metal and not able to get a good enough signal.
    Jun 19, 2008 | Computers & Internet
    Wireless mobile service connect to eee pc 8 GB?
    MINHHANH::
    What type of o/s [operating system]? I did quick research and I saw Linux ? I think that they don't have SOFTWARE DRIVERS for your o/s. Not in USB,connect 881 and not to loose you u, they did not tell you.
    TNTEE::
    you already have a wireless receiver in your laptop, u just have to configure it [Tell it what to do!]
    Then u goto the internet explorer or some other BROWSER and get on WIFI if you can receive a signal from the air
    Apr 16, 2008 | ASUS Eee 4G Notebook
    New roof
    On my receiver there is a setting for signal strength on the menu/setup. You can have some one watch the signal meter and try but with out a meter at the dish you might be looking for a while. There are websites that give the look angle and azimuth from your location if you have a compass.
    Dec 29, 2007 | Directv D10 DTV Receiver
    Cell Phones Logo
    104 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
