Question about SanDisk Sansa View 8GB MP3 Player - Black
Freezes after 8 secs (No sound or anything)
This only started happening in the last couple days and its driving me nuts...i try to play a song..any song and i only get 8 secs of it and the screen freezes, sound stops, and no buttons work...i plug it into my computer and it freezes after 10 mins...HELP PLEASE!!!
I registered my Sansa View in sandisk site, and the support sent to me these two solutions. I have a similar problem like you and I'm still haveing problems but meaby these steps working in your sansa view.
regards
Diego
Nr 1:
Let us update your player's firmware:
Step 1 – Connect the player in Recovery Mode.
1. Turn off the player.
2. Slide down the Hold switch along the left side of the player down so the orange is showing.
3. Press and hold the HOME button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer (XP) or Computer (Vista).
5. Release the HOME button.
Download and update the firmware.
1. Download the firmware file:
Click Here for the Sansa View Firmware update file
2. Extract the zip file.
3. Copy the extracted firmware files (*.dat, *.rom, *.mi4, and *.fnt) to the 16MB-FORMAT drive.
4. Disconnect the player. This will now start the firmware update.
5. Slide the Hold switch to the unlock position.
6. Turn on the player.
Nr 2:
It appears that this is caused by file corruption in your player's memory. Usually, formatting your mp3 player resolves this FM issue in your player.
Formatting your Sansa View Mp3 player in Disk Management:
WARNING - FORMATTING YOUR MP3 PLAYER WILL ERASE ALL MEDIA FILES IN YOUR PLAYER, PLEASE BACK UP IF POSSIBLE.
1. Make sure the Sansa View is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << ). Do not let go of the left button until the player is detected as Removable Disk.
5. The Sansa View should now be connected in MSC mode and should appear as a "Removable Disk" or "Sansa View".
6. From the desktop, right click My Computer, then select Manage. If you don't see My Computer on the desktop, click on Start and right click My Computer from there, then select manage.
7. On the Computer Management window, click Disk Management from the left pane.
8. On the right side, locate your sansa device on the list (it might be recognized as removable disc), right click on the sansa device, then select Format.
9. On the Format Window, select FAT32 under File System and make sure that the Quick Format option is not checked.
(You might get a warning window about your files being deleted when you format the device, if that is not an issue for you, click ok.)
10. Click OK to start formatting the device. This should start the format process.
11. Once the formatting is done, unplug the device from the computer. Let the device refresh.
12. We can verify that formatting is successful if it shows no files on the player.
Posted on Nov 04, 2008
When i downloaded songs on my rca mp3 player it freezes
@ _ @ thats just it you can't turn on the thing to delete them, even your computer won't do it. FAIL....
Jun 03, 2010 | RCA M4304 Digital Media Player
Ilo freezes
Try this...
1. Open up your My Computer Icon to show your drives installed on your computer and take note which ones are installed. Leave this window open.
2. Connect your ILO device and wait for the two additional movable disk drive to appear in your My Computer window (ex:
removable disk drive [E:], removable disk drive [F:])
3. Right click the first drive that appears (ex: [e:] if the removable drives show as [e:] and [f:]) and select format
4. Click "start" on the format window
5. Disregard the warning notice that pops up
6. Once that is complete retransfer all of your music and then
your device should function properly.
Jan 26, 2008 | iLO (2 GB) MP3 Player
Song List Help
Alex, I'm going to attempt to help here.
After you select "All Songs" you're saying that it simply shows the previous song that was played and starts that one right?
A couple of things, normally the unit doesn't play anything by default when turned on. Usually it will allow you to select from the menu and if you don't make a selection at this point and attempt to back up, sometimes it will start playing the last song used.
Here's a couple of work arounds, first, you can try to use the smaller silver button (above left of large dial), press it and move the menu back to your options or choices such as Artists, Playlists, etc. and select something different that way (this is while the current song is playing).
Another possible solution is to select from the menu either "Artists" or "Browser" and choose another file.
This unit can demonstrate weird behavior at times and like anything else, the more you mess around with it, the more you'll figure out its quirks.
Hope this helps Alex.
May 24, 2010 | Coby MP-610 MP3 Player
Nhl 2010 problem
just bought nhl 10 a couple days ago and started playing 'Be a GM' 24 hours later, when i go to play it the game freezes a lot and i can only play my ahl team but not my team only the opponent team. when i try to put someone on the trading block it also freezes. can anyone give me some advive?
Sep 16, 2009 | EA - Electronic Arts NHL 08 for Xbox 360
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
SD card problems help!
try taking the card out, rebooting the phone, and putting it back in
Sep 03, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Freezes/changes song randomly during certain songs
i would suspect the song to be corrupt or you could try downloading the new firmware
May 15, 2008 | Philips GoGear HDD6330 MP3 Player
Selected songs won't play
What happened after you restored the iPod? Did you transfer the songs again and again, they didn't work? If so, your hard drive is probably defective, have you heard it making clicking noises?
Dec 24, 2007 | Apple iPod MA446LL/A MP3 Player
VISUAL LAND (VL-557) MP3 PLAYER - Technical Problems
My Insignia MP3 player had a weird malfunction. it was fine on my ride up to school ( about 8-8:30 am)...but then after i finished band practice (6:00 pm) the music would play but the screen didn't come on..it just turned this dark blue-ish color. So i cant see the words, pics, or ANYTHING..
someone please help...its not even a year old!
if you have any suggestions, please email me @ Mika.GIRL14@gmail.com
thank you
Nov 13, 2007 | SanDisk Sansa Clip MP3 Player
Ipod problem - playing songs in order
sounds like you need a new hard drive, which has a little read-write disk in it that is getting finicky... just to get more use out of it lay it on side or other positions and hear if works ok...if so its diffently Hard drive. you know the sandisks are 2 gigs no moving parts why doesnt somebody put 20 together making 40 gigs and replace the failing Ipods!!??? just pure electronics and no moving parts and much smaller...not like a hard drive. I thought of this over 30 years ago looking at the first plug in video game.
Aug 31, 2007 | Apple iPod shuffle MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
131 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
