Question about Xerox DocuPrint C4350 Laser Printer
Xerox c4345 transfer belt
How to get rid of transfer replace error code.
4 Suggested Answers
  • 10406 Answers
SOURCE: Xerox phaser 6120 has error code 16 transfer belt.
> bought printer new
Then, take it back to where you got it, and exercise the WARRANTY to get it repaired/replaced at *NO* cost to you.
Posted on Dec 28, 2010
jas247
  • 844 Answers
SOURCE: Keep getting the error message
Welcome to FixYa.
This error message means that you already have reached the 15,000 prints and the transfer roller needs to be replaced.
In some cases you can reset the transfer roller from the printers control panel. Try this:
  • Go to the Menu MAP (Main Menu)
  • Go to Supplies Info
  • Scroll and look for Transfer Roller Reset
  • If it does not have one, Go to Transfer roller life and see if it has a reset option.
If it does not have one, you need to replace the transfer roller.
Thank you for using Fixya.
Jas247
Posted on Jul 24, 2011
  • 360 Answers
SOURCE: Xerox Phaser 6360 The unit keeps
Replace photosensitive drum, which is a consumable part & has to be replaced when it is at the end of life.
Posted on Aug 16, 2011
My xerox 7132 machine is giving error code 093.311. Waht could be the problem
There are two silver "patches" on the transfer belt which can be seen by removing the fuser assembly. It is easy, just open the left side cover and unscrew two beige/yellow screws and pull apart the fuser (HOT!)
Transfer belt is a brown wide (VCR tape colored) belt. If you open the front door and turn the beige handle 90 degrees, it loosens the belt and you may little by little turn the belt from the left side. You will see the silver square sticker patches on the belt's front side.
Unfortunately, if they are scratched or worn away you can not replace them by yourself (unless you're a very clever person)
Aug 02, 2017 | Xerox Office Equipment & Supplies
I have a problem about transfer belt error 14
Error 14 is actually the transfer roller, error 16 is the transfer belt.
Error 14 is a transfer roller error and roller needs to be replaced. The part number is 059E05450 and can be ordered below:
http://www.iteminconline.com/059e05450_059e05450-xerox-6120-transfer-roller.htm
Jul 30, 2015 | Xerox Phaser 6120N Printer
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
Xerox workcentre 6015 092-651 error
That error indicates a bad ADC sensor. Try cleaning the adc sensor which is on the rear of the transfer belt. If that doesn't work, replace transfer belt as sensor is not sold separately.
Sep 18, 2013 | Xerox WORKCENTRE 6015/Ni Color
Error 917
917 Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
Code 917: The Transfer Belt Rotation Sensor indicates a belt error.
Initial Actions:
? Check the condition of the Transfer Unit drive gear.
? Cycle the printer's power.
? If the problem persists follow the procedure below.
Troubleshooting Procedure Table
1 Test the Belt Rotation Sensor.
Run the Service Diagnostics Belt Hole IC test.
Does the sensor function correctly?
Yes) Go to Step 2.
No)Replace the sensor. If the error persists, go to Step 3.
2 Test the Transfer Unit Motor.
a. Close the Interlock Switches for test.
b. Run the Service Diagnostics Transfer
Belt Motor test.
Does the motor operate?
Yes)Replace the Transfer Unit. If the error persists, go to Step 3.
No)Replace the motor. If the error persists, go to Step 3.
3 Check all pins on the HALL1 Harness for continuity.
Disconnect HALL1 and P/J310
Is the harness conductive?
Yes)Replace the Motor Driver Board.If the error persists, go to Step 4.
No)Replace the HALL1 Harness.
4 Check all pins of the DRV0 harness for continuity.
Disconnect the DRV0 ribbon cable.
Is the cable conductive?
Yes)Replace the Engine Control Board.
No)Replace the DRV0 Harness.
Aug 18, 2011 | Xerox Phaser 7400/DT Laser Printer
FAULT CODE 094-322. WHAT CAUSES IT AND HOW DO I GET RID IF IT?
ERROR CODE 094-322 RAP Second BTR Retract Failure
The error relates to the Second bias transfer roller not retracting. It could be a fault with the roller but i would open the transfer draw and check the connections and seating of everything and try it again. More often than not this clears the error.
Jun 24, 2011 | Xerox DocuColor 12 Color Copier
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
I have a Xerox workcentre 7345 and reported that the Error code 010-341. I Had already replaced Fuser. stil Getting the Same error code
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox phaser6110MFP transfer belt error cant
Transfer Belt Error Aproblem has occurred transfer belt in the machine. Unplug the power cord and plug it back in.If the problem persists
Cleaning the inside of the sensor of the belt and then not change you change the blet assembly moz-screenshot-1.jpgmoz-screenshot.jpg
Apr 22, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox DocuPrint C4350 Laser Printer Logo
20 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
