Question about Dell W4200 42 in. HD-Ready Plasma Television
Computer speakers in my DEll W4200 plasma TV
My speakers have been damaged and would like to use computer speakers in the meanwhile but it does not work!!!!
if you can answer this please email me
hockeypassion99@hotmail.com
  • 1 more comment
  • sehomoky Nov 11, 2008
    our speakers on our 4200 just stopped working over the weekend.
  • Anonymous Feb 24, 2009
    how much would that part cost
  • rico7377 Feb 24, 2009
    My dell w4200 output speackers conection are not working. The tv Repare man tould me that it was the audio amp board was not working.
    Is the audio amp board to expensive?
    New Friend:
  • 90 Answers
Are you able to get sound on the other a/v components? hdmi, side audio, composite 1, composite 2 etc...? If sound, your audio amp is OK. Otherwise, its fried, disablling secondary audio source. TV needs to be open and audio amp board inspected. If burnt on bottom, there's your problem. Needs replaced
Posted on Jan 31, 2009
The sound on my Dell W4200 is crackling some times even when the sound is on mute. Sometimes the sound is fine, other times no sound and other times the crackling noise. Any idea what problem may be?
Hi There,
Crackling sound is often an indication of bad connections to the speakers. Are you listening with the built-in speakers or through an external amplifier?
If you are listening through an external amplifier or speakers, check all of the connections to make sure the cables are properly inserted, and wiggle the cables from each end and the middle to see if that reproduces the symptoms. Sometimes a cable can become damaged from being squashed or bent, and it may be as simple as replacing the faulty cable with a new one.
If you are listening with the built-in speakers the situation might be harder to identify and correct. Sometimes it is as simple as nearby wireless devices or radio towers causing interference with the speaker. You can try repositioning wireless devices such as computer routers, cordless landline phones or radios to see if that helps.
However, over time the solder used to connect the internal components can wear and sometimes break the connection. For this type of situation repair is usually the only option. If the warranty of your TV has expired you may have to take it to a local TV service center. Typically a loose solder joint is easy to identify and fix, so the repair bill should not be high.
Please post back with your results.
May 26, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Access code to reset factory default settings
Hello:
To reset your Dell W4200 to the factory default settings, follow these steps:
  1. Press "MENU" on your remote
  2. Select "Setup" on the screen using your remote
  3. Select "Factory Reset"
If your TV is locked, you can use the default code of 3355 to unlock it.
Manual for W4200: http://support.dell.com/support/edocs/systems/W4200/
Mar 06, 2011 | Dell W4200 42 in. HD-Ready Plasma...
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Speakers for Dell 42 inch plasma TV
yes
i have them in stock.
how manny do you need.
see my web site
allrepair dot us
regards,
daniel.
Jan 12, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Speakers for my Dell 4200 Plasma TV
in stock at allrepair you have to call them
1-719-687-6997
Dell W4200 Display Problem
it may need a simple firmware update. look on the back of the unit, and tell me the A?? version should be A00, A01, A02. also, if you know how to check for firmware, Input 6,1,9. I need to know the firmware version 5?.? located in the center of the bottom of the screen. email me with this info, I may be able to further assist you.
Dec 17, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Dell W4200. Need original base / stand
Hi guys I have for sale two original BLACK COLOR stands for 42" dell plasma TV
Let me know if you are interested
Rod
Dec 07, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Dell W4200 42 in. HDTV-Ready Plasma Snow and Horizontal Lines
go to the menu and try the plasma restoration first. that will take a few hours and you probably same the $350.
Nov 05, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Dell W4200 42 in. HD-Ready Plasma Television Logo
301 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
