Question about Coffee Makers & Espresso Machines
Parts Braun coffee grinder Type KMM 1
Spare part required coffee bean hopper
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Posted on Jul 13, 2009
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Whole beans fall through the Grinder
You have to remove the coffee bean hopper, there are two screws on it. Below it is the grinder and there must be a rubber seal between them. Perhaps it is crooked or broken, and then the coffee beans pass and fall down.
Apr 27, 2017 | Saeco Magic De Luxe Espresso Machine
Stone in the grinder
On my Braun mill, I unscrew the single phillips screwon the receptacle end of the bottom. The other end is held by a plastic tab so I have to push the bottom plate slightly backward. When the bottom lplate comnes out a little, it has to be slid on the power cord to get it out of the way. Thlis did not ge the machinery out of the housing, but it allowed me to tap out nearly a cup of caked coffee. Hope this helps
Nov 21, 2007 | Braun KMM 30 Electric Burr Grinder
Take apart
My grinder went from bad to worse and finally stopped grinding (with the motor still buzzing but absolutely no grinding). Knowing I had to do something or throw it away, I pulled the clear plastic bean reservoir upward and separated it from the grinder body. I looked down the hole where beans go down to the grinder and found packed coffee ground blocking the hole. I cleaned the whole thing, put the reservoir back, and my grinder now works like new :-)
Oct 27, 2007 | Braun KMM 30 Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
60 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
