Question about Kenmore 62622 Microwave Oven
Kenmore microwave model 665.68681891 runs but won't heat
I experienced a brief power outage at my home today and now my Kenmore microwave model number 665.68681891 runs but will not heat. all functions on touchpad seem to work, but no actual heat.
  • 1 more comment
  • dachsie83 Dec 29, 2008
    I have the same model number. Just returned home after the holidays to find the power had been off briefly and the microwave is running! When you open the door it stops but the light stays on causing it to heat up. When I close the door it starts running again. Keypad shows locked and unable to reset. Please help!
  • sjk74 Feb 14, 2009
    I have the same problem, everything works but it doesnt heat anything!
    I have the same problem as well.
  • Kenmore Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
My Kenmore elite microwave model 401.88523011 has lost power. The electrical outlet still has power to it. Is there an internal fuse or circuit breaker that may be causing the power outage?
Your microwave has an internal fuse. Usually 10 to 20 amp. You can pick some up at home depot or radio shack. Make sure you get the same amps and volts as the original fuse. Will be printed on your microwave some where usually. And if its one that is part of a double oven deal make sure that you check you're circuit breakers for the kitchen. Good luck.
Dec 16, 2014 | Kenmore Microwave Ovens
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
Kenmore Microwave model 721.80019 does not heat
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. As there was power loss due to storm so I believe it could either be the the high voltage circuitry, or the circuit board . To resolve this problem, you need the assistance of a qualified appliance repair technician.
Please do rate the solution as FixYa and revert for further assitance.
Jun 07, 2009 | Kenmore Microwave Ovens
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Kenmore 565.6050.9990 microwave dead
Start taking all screws out until you can access fuse.
Sep 17, 2008 | Kenmore 62622 Microwave Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
But please reply back with your full model number so we can help you.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 15, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore Microwave 63252
Microwaves use a special ceramic fuse that has probably been popped by the outage. You have to take the cover off and it looks just like the regular cylindrical glass fuse except this one is white instead of clear. I think radio shack has them. Hopefully the fuse stopped the power surge before it got the front panel controls.
Dec 31, 2007 | Kenmore 63252 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
630 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
