Back to:
Tags:
Jenn-Air 24 in. JDB1080AWS Built-in Dishwasher
Dishwasher fills tub continuously
posted by a-yacht on Aug 13, 2006
Dishwasher fills tub continuously until float turns it off whether in cyle, during drying or after cyle complete. That means during drying when the dishwasher is trying to dry the dishes the tub fills up preventing drying. This is a new dishwasher that I've never used. I allways noticed the tub was full of water, but thought that was just to keep the seals moist so they don't rot. I've been in my house 5 years and only hand washed my dishes because it was more convienient. Now that there are more people in my life I want to use it. Is there something wrong with the curcuit board? It's like the fill switch works separately or own its on accord, is this right?
Comment by a-yacht, posted on May 12, 2007
Reseting the harness did not work. Replaced the CPU for $80.00; works flawlessly now.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 14, 2006
FixYa! (100)
catriver
Rank:Guru Guru
Rating: 94%, 2650 votes
Ayacht, the fill is a timed fill controlled by the control board (part number 99003158). The float is a safety device designed to cut power to the valve in the event of a failure. The fact that the float is doing it's job and stopping the fill tends to lead me to believe that it is not the valve but the board giving you the problem. You can drop the bottom panel and check voltage at the valve to be sure. Because it's been sitting for so long you might want to reseat the harnesses on the control board to see if that corrects the problem. Catriver..post back.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dishwasher fills tub continuously:
I don't want to Accept this solution
Can you Help with these Dishwashers problems?
Dishwashers
are dishwasher is not turning on after replacing motor
Dishwashers
to whom it may concern, my miele dishwasher does not...
Dishwashers
The lights on the timer don't light up complete numbers,...
Dishwashers
I have a maytag DWU9961ABX INTELLISENSE PLUS dishwasher...
Jenn-Air 24 in. JDB1080AWS Built-in...
The control panel is not working. When pushing the buttons...
Loading problems.
Repair Service
Find Dishwasher Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
