RIH-8067 Split System Air Conditioner
The unit's Timer light is flashing, when the power is turned on. How do I stop this from happening?
Thank you,
Ash.
  • sir_ob1 May 21, 2009
    same issue here....twice. the head unit motherboard needs replacing.
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
Sharp AY-A249J Split System Air Conditioner not working, the timer light flashes 5 times and the power light does not flash at all, the remote has limited function, it turns the indoor unit on and off and...
Thanks for your replies, I had a Sharp authorised tech look at it and im told it's the indoor circuit board. Im told its a $360 repair job all up, that sure beats replacing the entire ac or putting up with the heat...
Dec 07, 2012 | Sharp AF-S120FX Air Conditioner
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Hi, i have 2 daikin air conditioning unit, 1 is working perfectly but when the 2nd is turned on the power light just flashes and nothing happens, any ideas thanks.
The flashes are codes for different problems the unit may have, count the flashes and check your owners manual this will tell you the problem and the solution, or turn the breaker off for 5 minutes and re-start the unit this will reset it the unit should work if the problem start again you will need a service man. hope I was able to help you.
Nov 27, 2009 | Cfm Daikin R410a Split System Air...
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
