Hi, I read your instructions for removing the nunator from a Calypso washing machine. My machine's nunator doesn't seem to be going through its proper wash motion. The washer goes through its cycles, but the clothes don't get moved (sounds like the nunator is vibrating during the wash cycle). The drain and spin cycles work fine, but the clothes aren't getting clean. No error messages are coming up, so what's wrong?
The spin and soak cycle works properly and the tub will rotate clockwise. When the tub stops and the nutuate is supposed to start, it doesn't....if I stop the machine and rock the wash plate by hand, then restart the cycle, it will nutuate properly until it switches back to the spin cycle. On next nutuate cycle, it will repeat and not work properly until "nudged".
Thanks in advance for any help.
You can't post conmments that contain an email address.
Hi , I,m online now trying to fix my calypso dryer problem , ijust got done fixing my washer 10 minutes ago (clogged pump) . In the past I have unplugged the units when they acted up (re-boot) and worked up til this sunday . Good luck !!
Rob
The following advice gives the steps necessary to remove the wash plate (or nunater) in Calypso model washers.Common complaints of articles of clothing getting caught in the wash plate and/or lodged under it, may facilitate the need to do this:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support.Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate.Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate.Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate. 6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it.The inner wash plate is keyed and should only install one way. 7. Insert the main wash plate and insert mounting bolts.Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly. 8. Reinstall the center dome on the wash plate by snapping it back in place. 9. Reinstall, the balance ring on the wash tub. The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled: Wash Plate Dome Main (Outer) Wash Plate Inner Wash Plate Leveler Assembly Inner Wash Plate Seal U-joint
Searspartsdirect.com has an excellent exploded view illustration of the wash plate assembly and components to illustrate everything I’ve discussed in the steps above.Just type in your model number and click on the “Washplate, Basket and Tub” heading.At a minimum you should replace the Inner Wash Plate Seal anytime you break the seal.This will minimize the possibility of leaks. I hope this information is found to be helpful.
It is common for clothing to get wrapped around the u-joint, or leveler assembly. Use care when removing any garments not to damage any if these components under the nunater.
Let me know if you have any questions. I hope this helps you.
you have a bad u-joint assy,comes as a kit with the leveler..they used to put instructions on replacement in the kit.i assume they still do but i haven't done one in a while.good luck
A common clog point for the Calypso is an area under the wash basket at the inlet hole for the pump. You will need to remove the wash plate (nunater) to get to it.
The wash plate (or nunater) can be removed by following these instructions. It may seem like a lot, but the wash plate will not come out of the tub unless you follow the necessary steps:
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. The leveler sits below the wash plate. This leveler is keyed and the wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. NOTE: When putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly.
Now...using a flashlight shine light down through the larger holes in the wash basket towards the rear of the wash tub. There is an inlet hole leading to the pump that commonly clogs with lint or hair. You can clean any debris from this area by using a section of wire coat hanger with a small hook fashioned at one end. You will need to pull the debris up through the holes in the wash basket. I have responded to numerous service calls for this error and 90 percent of them have been because of a clog in this area (yes, it is a crappy design). Using the shop vac may also be resourceful if you use a small adapter to pull debris up through the wash basket. DO NOT pull a suction from the pump as you may actually pull the debris further into the pump.
Good luck to you and I hope this helps you. Let me know if you require additional assistance.
I can assure you this IS a common problem. I can't tell you how many customers I have had in the past that complained about their Calypso's leaving the same marks on their clothing. The problem occurs because of the suction on the clothes as the washer extracts water from them during the final nunator cycle. The nunator is the wash plate that the clothes get caught in. The manufacturer's cure for this problem was to come up with a modified control board that reduces the final nunator time and minimizes the suction action on your clothing. The replacement control board part number is 8571359. I have ordered and installed this board on a few Calypso's. I'm surprised that nobody advised you of this in the past. If you call Whirpool back and they deny this, I got this information from them. It may be worth your while to contact them again to see if there is a recall on this and if they would cover the cost of the repairs.
I don't know of a "permanent" fix, but I do know that replacing the nunater (wash plate) may help. Especially, if the rubber around the edge is starting to crack or curl, creating areas where clothing can catch. This is a known problem with the Calypso. As I was instructed, the problem was attributed to an excessive nunator time at the end of the wash cycle. Such a vacuum was being generated that it was pulling clothing into the edges of the nunator, leaving rubber marks and/or clothes becoming lodged. The manufacturer modified the control board to reduce the nunator time to prevent this. I can provide you with a part number, but do not know if the manufacturer will cover the cost of replacment. If interested, let me know. Do you need advice on how to remove the nunator (wash plate)? Or, did my previous post explain this enough for you? Please post back if you require additional assistance.
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub. - Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
There was a noted problem with the Calypso washing machine involving the control board. The machine had a tendency at the end of the wash cycle to pull such a vacuum to remove excess water from the clothes that it would pull clothes under the nunator (wash plate). This cycle consisted of a 30 second drain that often pulled such a vacuum that clothing would sometimes become stuck. The manufacturer came out with a replacement control board that took the 30 second nunator cycle and reduced it to (I believe) 10 seconds. This was supposed to minimize the possibility of clothing damage. The part number for the new control board was 8571359. There should have been a service flash out on this, but I'm not certain. You can try to get in touch with Sears at 1-800-252-1698 to inquire about this. I don't know if the manufacturer will cover the cost of replacement, but they SHOULD. This was a KNOWN problem, so they should be familiar with the circumstances. Let me know if you decide to pursue it and see what they may have to say. I hope this has been helpful to you.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Your clothing is probably tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly.
PS Don't forget to put the tub ring back in.
