Question about Acu-Rite Measuring Tools & Sensors
Flashing Temp Display on Acu-Rite Thermometer model 2002
The outdoor temperature display constantly flashes even after new batteries. Why?
SOURCE: The time display won't stop flashing
Q: Why does the time on my clock flash?
A: A flashing display is an indication of low battery power. We recommend using fresh alkaline batteries. We do NOT recommend using rechargeable batteries or heavy duty batteries in any of our digital products. They are not designed for this type of use and may cause the unit to perform as a defective unit or not at all. They will also cause the display to flash 100% of the time.
Posted on Jan 16, 2010
  • 17 Answers
SOURCE: my acu-rite wireless thermometer model #00604RX
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Posted on Oct 21, 2010
SOURCE: My acu-rite keeps beeping even after a battery
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Posted on Dec 01, 2010
SOURCE: I need instructions for my Model 00972 Acu-Rite
flashes continuously the time and the outside timp
Posted on Jan 09, 2011
SOURCE: I need a manual for
Here you go. May not stay up forever. http://www.weatherconnection.com/manuals/00592W.pdf
Posted on Feb 03, 2011
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
Apr 26, 2009 | Acu-Rite Adagio Clock Radio
Measuring Tools & Sensors Logo
519 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
