Question about Amana Freezers
Where is defrost timer on amana ars2367as
Refrigerator and freezer seem "stuck" in defrost. When out works fine
  • 7 Answers
SOURCE: Traulsen freezer URS48DT
Turn cold control to Max. This keeps your compressor running for this troubleshooting exercise. Find and manually advance the defrost timer with a screwdriver or something similar. This will shut the compressor down and bring the defrost heater on. If this happens then you will know that your timer is bad.
If it is not that, the next thing to look at is the defrost heater itself or the thermal overload on your defrost heater. This keeps your defroster from overheating.
Posted on Jan 24, 2008
jmgldsmth
  • 1869 Answers
SOURCE: Unable to find defrost timer for Frigidaire UFPD-15L
Gem corp. makes this part
Posted on May 20, 2009
SOURCE: sides of freezer warm to touch when starting
could be coils need cleaning? just read that at another site....said use a coil brush 2 times a year...
Posted on Aug 30, 2009
  • 3368 Answers
SOURCE: Amana SQD25VL coils cool, but deepfreeze fan does not engage
Sounds like a bad fan motor. Be sure power is getting to it.
Posted on Dec 03, 2009
  • 1218 Answers
SOURCE: refrigerator is not cooling
Good day,
You will need an ohm meter to check the parts.
Your defrost system has failed.
It is made up of 3 components, 2 of which are located behind the rear panel in the freezer compartment.
Remove the rear panel. There is a cooling coil, that has a calrod heating element that runs along it's bottom. As well there is a defrost thermostat ( a small round 1" disk) which is located on the top of the same coil. Both should be checked with an ohm meter to test for continuity. The heater should read no more than 30 ohms, the thermostat ( IT MUST STILL BE COLD BELOW 30 DEGREES) should read zero ohms. Note: The heater rarely fails, the thermostat has a high failure rate.
The third item is a timer, or a solid state adaptive defrost control. Depending on age, and model, it is located , behind the kick plate on the bottom front.
Or, in the fresh food compartment on the roof.
If it is a timer, you can turn the timer shaft when the machine is running until the machine shuts off. With it still turned on, wait 40 minutes.
If the machine turns itself back on, the timer is O.K. if not, the timer is bad, and needs replaced.
If the Main heater checks O.K. and it has a solid state control, then replace the thermostat in the freezer compartment, and the solid state board.
Below is an excellant tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Posted on Jan 20, 2010
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
Mar 31, 2014 | Avanti FFBM921PS 9.2 cu. ft. Bottom...
My amana bottom frezzer refrigerator keeps frosting up
check the defrost timer , element and defrost temperature safety.
and make sure the fan works.
Apr 16, 2013 | Amana Freezers
I have Ice on the bottom shelf of the freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
Refrigerator is not cooling
Good day,
Jan 20, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer fine, refrigerator not very cool???
Auto defrost system failed. The defrost system is made up of 3 parts. The main heater, a calrod unit similar to the bake unit in an electric range and is mounted to the evaporator coil located behind the rear panel of the freezer panel. The defrost thermostat ( often called a limiter ) which is located in the same compartment as the main heater and is a small disc type tstat clipped on or near the top of the evaporator, and lastly, the timer , which may be either the standard mechanical timer or a solid state device.
You need a decent knowledge of electrical and a working knowledge on the use of a VOM meter. If not, you can remove the components and take them to an appliance parts house to be tested.
Nine out of ten times it's the limiter, which is also the cheapest part. But I cannot confirm that. The second most common part to fail on your unit is the timer. Heaters rarely fail, but......
Oct 31, 2009 | Amana Freezers
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
Not recovering
Make sure the fan in the freezer is running circulating the air.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Freezers
Freezer is getting to about o degrees but refrigerator section wont go below 50 this is amana side by side asb2623hrw also changed the defrost timer about a month ago and blew off the coils from underneath...
Check your lower air shutter that lets cold air move from the freezer to the refrigerator's. You may have something blocking the air flow, food, plastic, etc... There should be a dial that opens, and closes the door.
Sep 01, 2009 | Amana Freezers
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Jan 20, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezers Logo
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Gil Shultz
John Tripp
John Tripp
Are you an Amana Freezer Expert? Answer questions, earn points and help others
