Question about Dryers
Where wires to hotpoint tvm562 tumble dryer motor go
I need to no what wire goes where as iv replaced belt but disconnected wires that attach to the front (inside at bottom) of machine.be very grateful if sum1 can help.thanks
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
  • 1314 Answers
SOURCE: tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Posted on Mar 12, 2008
SOURCE: how to replace the belt inside my tumble dryer
try a bra
Posted on Oct 03, 2008
SOURCE: tumble dryer when switched on cuts power to all sockets in house
i had the same problem after it tripped the fuse i looked in the dryer where the cloths were and saw that there was a buildup of steam in the drum. i then realised that because i was using the dryer in a very cold outhouse in the winter the water in the cloths was condensing too fast for the machine to process, this in turn caused a a backup of steam in the drum which backed up so much that the heating elements shorted out and caused the fuse to trip out. i hope this helps. after moving the dryer to a warmer part of the house i have had no problems.
Posted on Dec 08, 2008
  • 686 Answers
SOURCE: Drive belt on Tumble dryer
YOU NEED TO POST YOUR MODEL NUMBER AND THE MAKE
Posted on Apr 10, 2009
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
Need to take apart a hotpoint tumble dryer vtd00t
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Sep 21, 2010 | Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Oct 30, 2009 | Hotpoint Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Apr 06, 2008 | Dryers
Dryers Logo
147 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
