Palm tungsten E2 touch screen unresponsive - Computers & Internet
  • 1,847 Answers
Try take the battery off and put it back, restart the PDA and then try.
Posted on Oct 25, 2008
Unresponsive touch screen on Palm Tungsten E, buttons work
Often the problem on these is contamination that gets under the edge of the escutcheon which effectively presses the screen out of the usable area preventing entry in the normal area.
Using special screw driver (very small TORX) remove the covers and clean the screen edges. Note one has to gently pry the cover off when ALL screws are out.
A "sometimes works" method is to run a piece of paper or thin cardstock around UNDERNEATH the rim of the escutcheon to clean the contamination.
Note, you MAY need to "recalibrate" the screen after these procedures.
Jul 27, 2010 | Palm Tungsten E2 Handheld
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2
Try the hard reset procedure.
If still is failing, then the digitizer is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
May 17, 2009 | Palm Tungsten E2 Handheld
I have a moving target on screen and can't access anything else?
pls try to hard reset like this if it helps see the link,kb=PalmSupportKB,t=ooccase,case=obj(15574)
if problem persists then yes u are gettin screen alignment problem bcoz of digitizer fault it is faulty u have to get it replaced but i dont think it is worth if warranty is out if u really want to do it then go to below link
I Recommend the Following Tools for this Repair
  • Case Opener Tool - Part Number: XX1521
  • Torx Driver - T5 & T6 Driver Set: XX1127
  • This is a complete screen for the Palm Tungsten E2 unit. This includes the LCD and Digitizer.
  • This is a refurbished screen and comes with a 30day warranty.
  • This screen will only work with the Tungsten E2 units and NO other models. All sales are final. No exchange refund or return. There is a 30day warranty with this item directly from
  • see the Video here
    Mar 20, 2009 | Palm Tungsten E2 Handheld
    Tungstun e2 touch screen not working
    Perform hard reset. Press on and reset at same time. If this was helpful, please post as such. If it fixed it.....fixya. TY
    Jan 19, 2009 | Palm Tungsten E2 Handheld
    Palm Tungsten E/E2 digitizer - fragile?
    Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
    Dec 30, 2008 | Palm Tungsten E2 Handheld
    Can I sync an Ipod touch with my Palm Desktop for windows?
    I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
    Dec 27, 2008 | Palm Tungsten E2 Handheld
    I noticed this problem with mine and solved it by loosening the 4(four) T5 screws in the back. The problem is caused by a swollen battery. When the PDA is left charging for extensive periods of time, as mine was(several months of inactivity and never thought to unplug it), the battery will swell. It's still a good battery and holds a charge, but the increased girth presses on the internal boards of the PDA causing the screen to register a continuous "touch" and therefore seems locked. It's actually waiting for the phantom touch to release so it can act. Unscrewing the fasteners allows the body to expand, thereby releasing the pressure on the screen and letting the phantom touch go away. I'm going to see how well my e2 does without the screws in it at all for a few days. The front and back panels have "clips" molded into them which hold to the side frames, keeping it closed. But the fasteners are there to ensure the PDA doesn't fall apart all together. So, wish me luck. I'll report back in a few days and update this.
    Oct 25, 2008 | Palm Tungsten E2 Handheld
    Computers & Internet Logo
    101 people viewed this question
    David Payne
    David Payne
