Question about Toshiba DKT3010SD Corded Phone
DIAL RESTRICTED? When trying to dial out The screen reads dial number restricted. How do I turn this off or fix this problem?
3 Suggested Answers
SOURCE: setting up speed dial numbers
User Programming Mode
�� To enter User Programming Mode, press the Program button ...or dial #9876. "USER PROG MODE" appears on your LCD. The Program LED is steady green. �� To exit User Program Mode, press Program … or go off- and on-hook press #9876. Note A IPT equipped with a headset adapter ignores the hookswitch. It can only exit User Programming by timing out (approximately 15 seconds).
Posted on Jun 10, 2008
I HAVE THE ANSWER YEAH!!!!!
I just started working at my job and we call the same labs everyday and I really needed this speed dial to work.
These are the steps; I hope it works for you.
1.Do not lift the handset.
2.Press Redial
3.Put in the speed dial # example 60
4.Put the entire phone # inc. area code.
5.Press Redial
It should be stored.
Have a great day.
Posted on Jan 29, 2009
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
What does outgoing call are restricted by fdn mean
FDN(Fixed Dial Number) if enabled, allows you to restrict your outgoing calls to the limited set of phone numbers that are included in the Fixed Dialing Number list.
Jun 10, 2014 | Motorola Mobility Verizon Wireless Droid...
Outgoing calls are restricted by fdn
This means that Fixed Dialing is enabled to certain numbers. You'll have to disable this function in order to call other numbers.
Mark
Motorola Support
My phone will NOT let me call out when i dial a number it says its restricted. how do i fix this problem???
Here's a phone system lesson. Panasonic discontinued your TD phone system about 8 years ago, so you either got a super deal or the system has been installed that long ago. Restrictions are programmed into the system by an installer and manager. There's a Class of Service override access by dialing 47 on the intercom and a code. Since the 7436 is a special phone, it's probably the one attached to extension 101. If that phone is restricted, clearly whoever owns the system doesn't want whatever you're dialing to be dialed.
Now you wouldn't be asking "someone on the internet" for instructions on how to beat the restrictions would you?
I didn't think so. Check with the system owner or installer.
Carl
May 18, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
Jun 14, 2010 | Samsung SGH-t219 Cellular Phone
Hi i have lg from verizon. please tell me the number for restricted? 82 or 86 thxs much
I am guessing you want to make calls and not have the recipient see your number on caller ID. If that is the case, you can do one of two things. 1) Call customer service to have caller ID turned off permanently. The only problem with doing this is people you call who have in-network minutes will not get the benefit of those minutes because the phone will not recognize your phone as another Verizon Wireless phone. 2) On a per-call basis, dial *67, then dial the 10 digit phone number immediately. Again, if the recipient is a Verizon Wireless customer, s/he will not recognize your number and will not be able to take advantage of in-network minutes. This will work for one-call only. You must do it the next time you want your number restricted.
Sep 13, 2009 | Cell Phones
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
Special code
i need please a special code for i415
Jul 04, 2008 | Motorola Mobility Boost i415 Cellular...
д.ї.Щ.є
Most likely his phone is set to restrict. If you want to, you can have your phone changed so know one can call on restricted which means this guy would have to dial *82 and then your number so then you could see his number
Jun 30, 2008 | Nokia 2610 Cellular Phone
Toshiba DKT3010SD Corded Phone Logo
109 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
