Question about Sharp AR208D Copier
System error f5-02
Get error on printer power on, after warmup
How do I remedy error SC 552?
change the main motor or clear the eroor
Sep 10, 2015 | Ricoh Aficio SP C811DN Laser Printer
Samsung clx-3175fw stuck in warmup mode
replace it , its having some kind of hardware problems
Nov 11, 2013 | Samsung CLX-3175FW Multifunction Laser...
HOW TO CLEAR AN ERROR [ERROR546]
Hello
Error 546 is a warmup error, when the fuser does not reach fusing temperature within the warmup timer period.
You could attempt to remove the fuser yourself, and clear carbon buildup, or you may have to completely replace the fusing unit.
You can clear the error by going into service mode, and selecting reset.
Aug 07, 2012 | Ricoh Aficio 150 Copier
50.2 error hp lj m4345 mfp
50.2 is a fuser warmup error.
If you have technical experience with printers, reseat the fuser.
Problem could be the fuser, the DC Controller or the power supply.
Have someone that works on printers take a look at it. If you haven't
done it before, you arn't going to be able to replace the DC Controller or power supply.
Aug 12, 2011 | HP LaserJet M4345 MultiFunction Printer
Is the procedure to correct a 50.2 fuser error the same on the Laser Jet 5100dtn as discribed on the 4100?
50.2 is a fuser warmup error. Books to turn printer off for 20 minutes, if error is still there after powerup ... reseat the fuser. Then replace power supply and then DC Controller.
It's basically the same on all laser printers.
Sep 14, 2010 | HP LaserJet 5100dtn Printer
Hp laserjet 3380 - MS Vista - scanner error, copying is ok
clear glass, replace ribbon scanner cable if no result - replace scanner
Aug 24, 2009 | HP LaserJet 3380 All-In-One Printer
Error CO500
This error code indicates low temperature at warmup.Can somestime be reset IF you can find the reset switch.On earlier models it was behind a small panel on the innards of the machine after you open the front door.Good Luck!
Mar 30, 2009 | Minolta Di3010 Copier
HP color laserjet 4600 dtn
It sounds like to me you purchased a bad fuser. Is the fuser brand new or a refurb? If so either way you will have to replace it with a working fuser . Good Luck!!
Nov 29, 2007 | HP LaserJet 4600dn Color Printer
Very Noisy Warmup cycle with my ML1210
put your ear closer to printer to detect source of noise, put all gears out and check each one and reassemple them, I hope you solve your prob.
Dec 28, 2006 | Samsung ML 1210 Laser Printer
Sharp AR208D Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
