Question about Quantum SCALAR 50E LIBRARY LTO3HH TAPE Storage Tape Libraries Ultrium Tape Drive
Servo init failure stalled Z in quantum scalar 50
2 Suggested Answers
  • 24 Answers
SOURCE: servo init failure stalled xy in quantum scalar 50
The unit will need to be repaired.  Consider getting a maintenance contract on it as my px502 cost me $700 to replace a sensor and cleaning and a few other minor issues.
Posted on Jan 23, 2010
2001 chrysler town and country. A\C heat Blowers will not work when controlled my front main pannel. It is a auto temp controlled system. The rear blower will work but no heat when controlled by the rear...
This may be similar to what I just fixed on an '00 dodge:
http://www.dodgeintrepid.net/showthread.php?t=89711
Accessing the Integrated Diagnostic System:
Procedure for Automatic Temp Control (ATC) equipped vehicles:
With the engine ON and the vehicle stopped set the temp to 75*F. Next hold down the Floor, Mix and Defrost buttons until the ATC display begins to flash. While the display is flashing, the system will run it's tests and calibrations.
When the display stops flashing, the tests and calibrations are complete.
The ATC display can only display one error code at a time. Any stored codes can be scrolled through by pressing the Panel mode button once for each code. DO NOT press any other button or you will have to start the test over. Note the codes and refer to the list below to determine what system is malfunctioning.
List of Climate Control DTCs:
23: Blend door actuator feedback failure (bad servo)
24: Mode door actuator feedback failure (bad servo)
25: Ambient temp sensor failure
26: ATC In Car thermister failure (ATC only, bad ATC head or ATC head disconnected while battery is connected)
27: ATC in car sensor failure (ATC only)
31: Recirculation door actuator stalled (stuck door or bad servo)
32: Blend door actuator stall failure (stuck door or bad servo)
33: Mode door actuator stall failure (stuck door or bad servo)
34: Engine temperature message not received (ATC only, bad ATC head or bus failure)
35: Evaporator sensor failure
36: ATC control communication failure (bad ATC head or bus failure)
37: Blend door actuator output shorted to battery (bad servo or wiring fault)
38: Blend door actuator output shorted to ground (bad servo or wiring fault)
39: Mode door actuator output shorted to battery (bad servo or wiring fault)
40: Mode door actuator output shorted to ground (bad servo or wiring fault)
41: Recirculation door actuator output shorted to battery (bad servo or wiring fault)
42: Recirculation door actuator output shorted to ground (bad servo or wiring fault)
43: Common door shorted to battery (probable wiring fault, could be a servo that failed in an odd manner)
44: Common door shorted to ground (probable wiring fault, could be a servo that failed in an odd manner)
45: A/C control blend door input open or shorted with respect to ground (MTC only, wiring fault or bad servo)
46: A/C control blend door shorted to battery (MTC only, wiring fault or bad servo)
47: A/C switch failure (MTC only)
48: A/C control mode door input shorted to ground (MTC only, wiring fault or bad servo)
49: A/C control mode door input shorted to battery (MTC only, wiring fault or bad servo)
50: A/C control electric backlite (EBL) switch fails (MTC only)
51: System voltage too low for calibration!!! (check battery cables, battery and alternator!)
Dec 10, 2014 | 2001 Chrysler Town & Country
Tape drive is showing red light 5, what is the issue
Please. could you talk me about the tape drive vendor?, (HP, IBM, others). Then, I thing can help you.
thanks.
Oct 22, 2014 | Quantum Technology Quantum Scalar i500...
Servo init failure stalled xy
Hi Edouard
This sounds like the picker has failed to complete the power on self test (POST).
This may be due to a damaged library or simply due to a tape blocking the picker movement.
POWER OFF!
Try opening the library to make sure your tapes are all properly located in the magazines and have not fallen out.
Also try gently moving the picker to see if you can locate any other obstructions. Be very careful as you obviously do not want to break the picker or anything else accidentally.
If you are in the UK and are still having trouble, click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Feb 28, 2014 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
Scalar 50
http://downloads.quantum.com/scalar/S50/manuals/81-81539-01_A01.pdf
The above may be helpful but i cannot see the error codes listed. This unit is the same as the PX502 so this may also help
http://www.sandirect.com/documents/PX500_Series_Users_Guide_81-81290-05_A01.pdf
Try also going to http://tape-drive-repair.com/ who have a repair centre to fix tape library units.
May 11, 2013 | Quantum Scalar 50 Library, One LTO-4 Tape...
Health benefits of quantum
This forum is for Hard Drives
Here is a link to their web site..
http://www.biomagneticbracelet.com/scalar-energy.htm
Hope this helps...
Nov 02, 2012 | Computers & Internet
DHCP Server Conflict
Login into tape library console using web browser and disable DHCP and provide Static IP .
Mar 30, 2012 | Quantum Technology SCALAR I80 LIB 1XLTO-5...
Servo init failure stalled xy in quantum scalar 50
Jan 19, 2010 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
2 BIG THICK LINES ON LEFT HAND SIDE OF THE SCREEN..
If the lines are vertical and go from one side of the TV to the other, it is most likely the scalar boards. There could be a loose connection from the PDP module (plasma panel) and the scalar boards. Otherwise, the scalar boards need to be replaced.
If the lines are horizontal, then the same thing as above except for the y-drives instead of the scalar boards.
Oct 05, 2009 | Samsung 50 in. Plasma TV
ADIC I500 - need a user guide in pdf form
Hi Brent ....
this is the direct link to the manual in PDF.
http://downloads.quantum.com/scalar/S500/omSi500UsersGuide.pdf
and this is the link to the group of documents for your tapelibrary ...
http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/SI500/Index.aspx#Documentation
kind regards Ed
Jul 08, 2008 | ADIC Scalar i500 Tape Drive
Quantum SCALAR 50E LIBRARY LTO3HH TAPE Storage Tape Libraries  Ultrium Tape Drive Logo
258 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
