Question about Lexmark Office Equipment & Supplies
Paper jam, i have tryed every thing got new paper, didnt work...
  • spikenard Oct 25, 2008
    model 5400 series laxmark...
    when it jam's it stops printing, jam's in paper feader, when i pull the paper out its creased, i have tryed with new paper, re postioning the side marks to fit with paper, basicaly the paper creaser's when it goes down between the rollers..
  • Mike S
    Mike S May 11, 2010
    what model is this?
    what happens when it Jams, where does it jam?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Sounds like your machine needs new rollers.. pick up roller and feed rollers..
Or something is blocking the paper path?
Clean the machine
I would suggest removing the ink cartridge
get a lint free cloth, a can of air, some q-tips and flash light and a lint free cloth.
Open the machine and blow it out with a can of air,
Look in it with a flash ligth and clean with the cloth or q-tipw and a small drop of the alcohol.
Clean the rollers in there with the cloth a slight bit damp, you will probably see the cloth get dirty from this.
Blow with air, let it dry out a bit..
put the ink back in, start it up and try again.
I believe there is a button that will feed paper through. do that then go to your print driver and print a test page.
This is what I do with my ink jet printer and usually helps it. I have never replaced the rollers, but clean them once in a while..
I repair Laser Copiers and Printers.. I have no ideal where to get parts for an ink jet machine.. usually suggest to through them away as they as designed to be disposal..
I hope this helps..
Mike
Posted on Oct 25, 2008
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Printer error 3533 CJX-1050W
too much paper being put into slot. paper it static so fan it beofre putting in
Feb 11, 2013 | Office Equipment & Supplies
I installed a new black ink cartgage and printed a alignment page. After alignment was finished I tried to print an envelope through microwsoft word and received a jam message. I have no paper missing on...
in the back of the printer, there is a plastic door try to dismount check if there is some thing triggers the "jam " error put it again and check, if not, try by your hand to put the head on far left side, some jam errors are from lost head position , then check the rolling rod it has plastic finger looks like half-round, if this finger is jammed and it's tip is not smooth with paper flow it will trigger paper jam
this plastic finger might jammed before and strongly removed the jammed paper which might changed it's curvature hopefully it work
Dec 07, 2010 | HP Officejet J5780 All-In-One InkJet...
A paper is jammed in my printer and although it gives directions to open cartridge 1 and then take out paper cartridge then remove jam, I cant see any paper jammed, but I did hear it jam when it happened....
in right side of the printer one green color lock is there pull that luck ......paper feed unit will come out there you can see the paper ......
if you want manul send me your mail id anantakumarjena0@gmil.com
Nov 02, 2009 | Kyocera Mita FS 1900 Laser Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
I have a canon pixma pi1800 i will not take the paper... it keeps saying paper jammed!! i tried cleaning rollers etc... tried printing a test shhet.. it says printing finished but i hadnt done it as it...
Here's a few things to try :
1. Blow it out with compressed air blower .especially the rollers and the paper feed area make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
after plug it back if the problem still persists then move to the next step
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.hope this helps
Jan 17, 2009 | Office Equipment & Supplies
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Poor Printer Quality
If you have the old drum put it back in and see what happens to the copy. if is better, then yu may have a bad new drum. They do have them. Poor copy quality is normally drum or toner in these Brothers. This model is an excellent machine by the way.
Jul 22, 2008 | Brother DCP-8040 Copier
My cannon MP530 has a paper jam but there is no paper and the feed switch isn't working i've tried turning it off aswell as the computer for the night and nothing....any ideas
There is another paper jam door on the back side of the printer incase you didnt know . I had a paper jam and could not see just by lifting top of printer. You also may have a small pice of paper triggering the sensor.
Jun 05, 2008 | Office Equipment & Supplies
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
