Question about Sanyo Microwave Ovens
EM-S7560W, replacement glass tray
Replacement glass tray
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken Glass tray
That model number isn't showing up. Could you confirm that?
Then I'll see if anything is still available for it.
Otherwise, here are two suggestions:
You place a microwave-safe saucer upside-down on the roller assembly (if equipped) and then put a microwave-safe plate right-side up on top of the saucer. You can also use another glass turntable tray that doesn't fit instead of the plate.
Be sure both are centered, checking them frequently to be sure shifting does not occur. Otherwise, a spill of hot material could result.
Another option is to check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round".
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
What size is the glass tray/plate?
My glass plate broke a very long time ago. you don't really need it. take a regular ceramic plate and turn it UPSIDE DOWN Then you can set anything on top of it to cook. Just a thought and Good Luck.
If you have other microwave problems check the videos below.
Nov 03, 2015 | Microwave Ovens
Turntable wont turn on my sanyo s7560w
Base on other microwaves I suggest that it is either the drive element or the turntable motor. If you hear the motor turning it is likely to be the drive element. To get to the drive element take out the glass plate and there will be a plastic part that engages the plate. You should be able to pull the drive element out with a little work. The receptacle of the element will likely be shaped like a circle with a flat spot. If the plastic looks deformed it is likely the drive element. Don't be surprised that they want $30 for a new one. Use glue on the drive element as a last resort. With the drive element in but the glass out run the microwave for a few seconds. Can you see the drive element turning? No? New drive motor needed. It may be expensive but it should be easy to replace.
Oct 23, 2013 | Sanyo Microwave Microwave Oven
WE need a replacement glass tray
If the model number is correct, the glass carousel tray is available at repairclinic.com for about $30. The item number is 1206676. I hope this helps you.
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken Glass tray
Apr 10, 2008 | Microwave Ovens
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Need glass replacement, what is part number or size
Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
Aug 31, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
190 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
