Hard drives and RAID
Could you please tell me how to install a third hard drive which would be separate from my two other drives which are in a RAID 0 array. Would a separate raid controller card make my system faster than using the onboard Intel ICH9R controller? Thank you.
  • Anonymous Dec 11, 2008
    Não consigo instalar o terceiro disco, está tudo abilitado e não dá certo.
  • Anonymous Jan 21, 2009
    raid controller
Rock01
Posted on Oct 27, 2008
I have two WD1600s, in RAID 0 configuration, on my Dell XPS, XP. One has failed. Can I just buy another one and reload the OS? Will any WD1600 do?
If you have a Raid 0, then both drives are tied into one. You could remove the bad drive, and just use the leftover one. But you would need to disable RAID in the BIOS.
Unless you know how you benefit from a Raid 0, I do not recommend keeping a Raid 0 if you have important files you need to keep.
you could also buy another drive, disable Raid, and install the operating system on the first drive, and keep leftover files like pictures etc on the second drive.
May 03, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
Tip
FAIL-SAFE FILE SERVER AND COMPUTER SYSTEMS If your data is very important, you...
If your data is very important, you should consider doing regular data backups because hard disk will fail at some at some stage in the future. This is especially true when you get an error message"hard drive is about to fail".
Depending upon how critical your computer or files server to you or your business, you should consider building a fail-safe computer or file server system using RAID technology. RAID means "A Redundant Array of Inexpensive Disks" and there are several levels of RAID.
For details of different RAID levels - click on this link -
http://searchstorage.techtarget.com/sDefinition/0,,sid5_gci214332,00.html
The most common of the fault redundant RAID systems are -
RAID 0 + RAID 1 provides fastest data transfer Mirrored hard drives.
RAID 5 is one of the most popular system, it data striping across hard drives with error correction. It has excellent performance with fail-safe system and allows for hot swappable hard drives.
There should be redundant powers supply inside the computer or file server in the event of a power supply failing.
Another consideration is to install a UPS (uninterruptible power supply) to prevent a computer or server shut down from power outages, as this will corrupt your data.
These systems do not mean you should not back up your data on a regular basis.
on Oct 20, 2010 | Computers & Internet
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Can't install Win Server 2008 on Acer Altos G320, it keeps asking for a driver. The Server currently has a HW RAID setup with two SATA disks and is running Win 2003.
you need to get the drivers foryour hard drives
and when u get to the hard drive bit of the setup click install third party raid drivers
or install hard drive drivers
good look ;)
Dec 23, 2010 | Acer Altos G320 Server
I an trying to set up raid 0 with two 500 gig wd hard drives on my abit awd9-max on a new install. I am running xp.raid is enabeled in bios. I hit f6 on windows setup installs dirvers but seems to be a...
In bios make sure the raid chipset is active. Ususally there's 2 one needs drivers one doesn't. I use the one that doesn't then in bios there should be a way to set up your array. Raid 0 is striping mode so you should only see one hard drive,the d drive should be the cd/dvd device. If this is right then you did it right.If it were raid 1 then you would see both hard drives,because one is mirroring the main drive for backup.
Dec 31, 2009 | Abit AW9D-MAX Motherboard
I have a dell precision 470, and it has 3 33gb hard drives (3 arrays) and have been formatted. When I insert the xp cd to install it, the setup tells me theres no hard drive in the pc??? I go to the system...
You may need to load third party drivers for them. During install windows asks you if you want to load them. Not knowing what kind of drives they are though i cant tell you what drivers, sorry.
Oct 27, 2009 | Dell Precision 470 PC Desktop
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
HOW TO CONFIGURE RAID
I needed to see your board & can at this site. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=493&DetailName=Manual&MenuID=1&LanID=0
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Luck!
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Computers & Internet Logo
648 people viewed this question
David Payne
David Payne
