Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
No sound, no picture, blinking LED.
I did an IC swap, and my tv would turn on, then immediately turn back off, so I tried to put the original IC's back in, and I could only get one in because the prongs on one are bent, and now my tv turns on and stays on but LED 28VID940 is blinking and I have no sound or picture. I'm going to try and get the other original IC back in in the morning, and if that doesn't fix it I'll need your help.
  • Anonymous Jan 05, 2009
    need to find info already posted on the loss of audio and video service on a 46 inch hitachi tv model 45F500
    Novelist:
  • 132 Answers
You must use the original stk 392-110 and stk 392-150 and do not mix them up. There is one of each.
All the suggestions about substituting other ICs for 110's are Bullplop, except for Hitachi manufacturers upgrade with changed resistor values included.
Posted on Dec 06, 2008
Tv plays about 2 minutes and picture and sound goes off, comes back on.Does this 3 times then tv shuts.turn tv back on and repeats sequence.
there is main board defective please replace the main board 3 time blink is dc alert which is happened in side the system ic & we cant replace the system ic so we replace complete main board
Apr 20, 2015 | Sony BRAVIA KDL55HX750 55-Inch 240Hz 1080p...
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
Power on, sound no picture for three seconds, power off, led blinks 6 times pause repeat
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
That means no horizontal output which could be caused by a faulty driver stage or even a faulty power supply.
Hope that helps.
Dec 09, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
