Neptune washer d3 error code
Off balance at first then randomly malfunctions on spin cycle and displays a d3 error code
  • 619 Answers
SOURCE: Maytag Neptune out of balance on spin cycle
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
Posted on Feb 15, 2008
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
dh1200s
  • 335 Answers
SOURCE: error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Posted on Oct 06, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Posted on May 23, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: Maytag Neptune TL stops spinning mid cycle?
RF_Tim
I feel you have a Clutch malfunction a very common problem with the machine. If you want to DIY the fix see my Clutch Fix post.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you need some additional help just shout back……..Rich
Posted on Jun 30, 2010
Why slow spinning?
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
Oct 17, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
The Service Manual for reference. Sears Parts Direct for reference.
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer will start the spin cycle but wont drain the water and just keeps trying to restart
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If it one of those machines I suspect a possible clutch malfunction. See this post for what is involved to do clutch maintenance or replacement.
Do you have any error codes to the display if it's a FAV6800A such as dC or uC unbalance codes. Is the wash tub banging around on Spin Cycle of the Wash Cycle? ……Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune tl washer will go half way threw cyle,start to spin,stop and start to spin,stop and start to spin .tried to unplug it restart and nothin, tried different settings still nothing. tried moving the...
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Oct 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
During final spin cycle a code that says DC of balance load and there is a bang from the tube
The DC code that comes up is just saying that the load is "off balance" to resolve this, open the washer and redistribute the last and restart.
The bang fron the tub that you hear is just from the load being off balance. Generally it's just the weight difference on the tub when the washer stops spinning. This is normal for an off balance load and is nothing to be overly concerned about.
If you are getting the DC code a lot, take a look at the types of loads you are washing. Are they small? Is it a mix of small and large items? Is it a few large items? This may be the answer to why you are having off balance issues. The Neptune is a very large washer, and can get off balance very easily with smaller loads. Try making loads larger or if you are washing for example sheets, try washing them in 3's. This will make it easier for the washer to balance the load.
Good luck! Please let me know if this was helpful!
Oct 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
