Question about Whirlpool Refrigerators
Whirlpool gsf26c5exwoo freeser keeps frosting and then refrigerator gets to warm
Only way i have been able to get to work is by unplugging refrigerator and letting it defrost manually.
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 213 Answers
SOURCE: RE- WHIRLPOOL NO FROST REFRIGERATOR NOT WORKINK NEEDS SOME HELP
whirlpool has a problem with the relayoverload thats plugged into the compressor. unplug the frig for about 5 min. then, while standing behind it plug it back in and listen. if you here a hum then a click, then you need to replace the relay overload. remove the back panel. the relay overload it plugged in on the left side of the compressor. very easy to replace
Posted on Nov 29, 2007
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
SOURCE: My freezer stops freezing and my refrigerator gets warm
everything defrosted in my freezer and now the refirerator is getting warm, here and there is sounds like something starts up and stops seconds later
Posted on Sep 15, 2009
Freezer frosting up and refrigerator is warm
check the condenser fan in the lower back to make sure its running,if it quits the compressor will cycle on and off to cool itself instead of the fan doing this operation,and the unit will warm up inside,then the compressor will again restart and any condensation in the unit will refreeze and cause frost
Dec 24, 2012 | Whirlpool Refrigerators
Hoover HCA 33 FSK
gp to repair clinic.com it sounds like the temp sensor or the or the defrost timer either way it probably isit defosting. The fan will run every time the it call for cold
May 29, 2012 | Hoover HCA390FFK Bottom Freezer...
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
I have side by side KSRA25ILSS and last week I have noticed-freeser is working OK,but refrigerator-too warm .I reseted sys. couple times,but coudnt fix problem. What is my next step,please?
you will need to check the damper control and make sure the door is opening properly to allow the cold air in the fridge this damper is normally located in the back f the fridge top left side.
then you will need to check the freezer compartment and make sure there is not alot of ice or frost build up.You will also need to make sure the evaporator fan is running in the freezer comprtment.
If there is frost or ice build up you can use a blow dryer to defrost it then remove the back panel and defrost the evap coil.you will need to check the defrost heater and temp sensor be sure there are all working good.
Jan 04, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Freezer ok, but refigerator is warm
first check to see if the controls have been changed,
one of the dials control overall cooling (freeser) and the other controls a damper that allows cold air from the freeser to travel to the refrigerator.
the other solution could be that there is something in the freeser, food or ice blocking the vent.
one other possibility is that the damper is stuck or frozen still.
if your freezer is ok, it is not a serious problem
May 26, 2009 | Refrigerators
Whirlpool arc7612. Fridge not getting cold. Freezer obviously working as it frosts up despite being 'frost free'. Slight gap in door seal near top of door. Last time we had this happen I unplugged it for a...
You have to replace the door seal. The seal may be a mundane technology and it isn't the only technology making a refrigerator frost-free, but it is the most important one. Warm moist air enters through the gap in the door seal, condenses on cold surfaces and freezes. The frost interferes with airflow and prevents the system from keeping the fridge cold. Turning it off for a day allowed the frost to melt.
Aug 03, 2008 | Whirlpool Refrigerators
Nov 28, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
