Question about Asko T712 Electric Dryer
Asko T712 dryer heating and running but making HORRIBLE banging noise
  • 351 Answers
SOURCE: ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Posted on Mar 20, 2008
  • 135 Answers
SOURCE: Our Asko dryer (T720) has
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Posted on Aug 02, 2008
  • 1382 Answers
SOURCE: My Asko stacking dryer makes a small squeaking noise
Hi, Check for the following:
  • Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time
  • Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
  • Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
  • Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Posted on Apr 18, 2010
Testimonial: "I was surprised and pleased with the feedback you provided. My son is going to look at it tomorrow. Thank you so much! Linda"
heatman101
  • 43501 Answers
SOURCE: My t712c asko dryer is making some loud noises.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
nfgnc
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: asko dryer running but no heat after changing
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
ASKO DRYER T700, DRUM IS MAKING BANGING SOUND AS IT SPINS.
Hi.
The loud banging noise in the spin part of the cycle is usually caused by bad drum bearings. The repair is carried replacing the bearing at the back of the drum. Such kind of replacement is carried disassembling most of the appliance to reach the back of the tub. If you have not done similar repairs before it may be better to call a technician ringing the Asko support number listed on the owners manual.
Regards.
Ginko
Sep 09, 2011 | Dryers
Element in the back seems to be heating but not spinning around. Cleaned filter.
the belt,motor,idler assemblage, drum glides and rollers are all parts the will effect the rotation of the drum. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Asko T712 Electric Dryer
I need to repalce the belt on an Asko T712 front loading dryer. Do I go in from the front or the back?
I took the top and back of my unit apart. Then from the back it is still not the eaisiet of tasks.
Oct 13, 2010 | Asko T712 Electric Dryer
When Dryer is on it makes loud banging noises almost like the cylinder is hitting the sides. It also seems to be excessively hot even set on low heat, and has an almost burning smell inside after running.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2010 | Asko T700 Electric Commercial Dryer
Hours for towels or sheets to dry
a dryer can only handel so much if you over load it it cant tumbel the load inside of it so the warm air wont dry them out,,,also what is it set on??? low or hight heat?? how wet are the sheets when you put them in the dryer??? is the dryer getting a good air flow,, it need to breath in lots of air,,,,and that hot wet air need to get out freely,,,if its even slightle blocked the dryer cant work well,,,how often do you clean out the dust filter in the dryer,,,(this should be cleaned every time you use it) also if the sheets just tiy them selfs into a big knot they wont dry
i hope this was of help to you
Jun 27, 2010 | Asko T712 Electric Dryer
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
Dec 19, 2009 | Asko T712 Electric Dryer
Asko t701 dryer makes exsessive noise and drum rotates slowly
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Sep 10, 2009 | Asko T701 Electric Dryer
Alarm F1 stoping dryer type T712, what the reason?
For information, behind front panel are optional hidden sensors and one of them had to be reset.
K,W.
Apr 14, 2009 | Asko T712 Electric Dryer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Asko T712 Electric Dryer Logo
83 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
