Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Bottom crisper bins
Bins are empty and filling with 1-2 inches of water. there are not any leaks from ice machine.are the settings correct?
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
Icemaker leaking water into ice bin during fill cycle
HI,
Need more information like model number as all units are not same and the answer could be different for each unit. Refer, ice machine, Freezer, all different unit and run differently. Please allow me to help you with the correct information. Thanks
Apr 15, 2016 | Refrigerators
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
Our icemaker makes cubes, but leaks water from the ice tray area, creating a 2 inch block of ice in the bottom of the ice cube collection bin each night.
Have a look at the manual on page 6 for adjustment procedure.
Also, your leak may be due to a water valve that is not able to turn off 100%. Valve replacement would be necessary. Unplug your icemaker electrical, and empty the ice. Leave the water turned on. If you keep getting water collecting in the bin, you are likely looking at a water valve replacement (not hard at all, just inconvenient).
Oct 12, 2010 | U-Line ULine BI2115B00 Black Echelon 15"...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Icemaker is leaking into ice bin.
it sounds like the water valve is leaking
May 07, 2009 | Kenmore Refrigerators
Ice not dropping
Press the little button on the bottom right of the ice maker and clear the tray of ice. The maker has to be turned on for the tray to tilt and empty. This corrected the problem for me. The freezer side may have been left open and and the ice maker filled the tray while the door was open, I suspect.
Nov 12, 2008 | LG LRSC26940ST 36" Side-by-Side...
No ice saved
If it's makes a good slab of ice the only reason it would melt would be a drain blockage holding water in the bottom of the unit or the water pan overflowing into the bin when it fills up. If you check the slab when it falls on the cutter and see a hollow looking spot in the middle you may have an evapoator leak. Yhis would require a service tech to repair.
Apr 22, 2008 | Freezers
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
