Question about D-Link (R) DIR632 WirelessN 8Port Router
Dir-632 slow throughput on wired lan
I have had this issue since getting this router. Large file transfers between two computers, both wired, results in 900kB/s to 1.1MB/s transer rates. If I plug in my old router (an older dlink which is also 10/100) I get around 9MB/s. I have the latest firmware and even tried a 3rd party fimware with the same results. Any idea?
  • D-Link Expert
  • 199 Answers
Try a factory reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Posted on Jan 06, 2017
  • 43 Answers
SOURCE: Dlink Di-514 slow
Need to change teh MTU settings in your router.once you  will change it,, it will work
Posted on Oct 23, 2007
SOURCE: D-Link DIR-100 Internet OK, LAN not working
Well , first : my english is poor. i will try to help you.
i also buy this router dir-100 and have the same problem. solve is this:
1. newest firmware (my is 1.12)
2. set up MTU on lower values {default is 1492 and I set my in 1480} and evrithing WORKS GREATS !!!!
try .
Posted on Nov 29, 2008
  • 167 Answers
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Posted on Mar 08, 2009
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Posted on Mar 17, 2009
SOURCE: wifi problem of DIR-300 dlink
Hi all,
Good day,
I have purchased a DIR-300 Dlink router. the connection is OK via LAN. the issue is the wifi I cant receive IP from the DHCP server of the router.
Kindly assist.
Posted on Jan 22, 2010
Dir-632 nat settings for xbox 360
Try looking here:
May 10, 2014 | D-Link (R) DIR632 WirelessN 8Port Router
D-Link router settings for connecting to a TIVO - wired
It is all about managing the IP's. The router and TiVo should be set to DHCP. This will allow auto IP addressing. It could also be set to static, but this requires more managing on your part.
Jan 02, 2013 | D-Link Computers & Internet
Very slow wifi connection from router dlink dir-600
I had this issue also. If rebooting the router does not improve or trying a new cable between your router and internet modem, you will have to do a factory reset. You can do this by logging into the router and selecting factory reset by locating a small hole on the back of your router, insert the tip of a paper clip for about 10 seconds with he power on, and this will reset your router to factory settings and of course you will have to set-up everything from scratch.
Maybe do a firmware update at the same time.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Dec 07, 2012 | D-Link DIR-600 Router
My internet connection is ok but when i sign on to messenger and start video call then my connection starts to slow down causing the sound to become like robot and the video on the other end freezez up
You didn’t mention if you’re using WIFI or not? If you are using wireless, try moving closer to the router for a better signal or use a cable. This is a bandwidth issue as video and voice are intolerant to delay so you get dropped packets and reduced call quality. If the problem is on your LAN then it could be solved by getting a router with higher throughput or using a wired scenario. Alternatively, if the problem is on the WAN a higher broadband speed may be appropriate.
Quality of service issues are difficult to solve on home networks because there is not normally any method of changing the priority of traffic.
Jun 28, 2010 | Computers & Internet
My dir-655 works great via laptop wireless but the
Follow the steps below on the concerned computer:
1. Click start button (extreme bottom left corner of the screen).
2. Click Control Panel from the list.
3. Click on Network Connections.
4. Right click on Local Area connection icon and click on properties.
5. Select Internet protocol TCP/IP from the list of components and click on properties.
6. Select "Obtain IP address Automatic".
7. Select "Obtain DNS server Automatic".
8. Click OK and close the window.
if the issue persists then try changing the cable between the router ad the computer. You may also try connecting the computer direclty to the modem to isolate issue.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Sep 21, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Question For Experts ONLY
It's true that using router and adapter of the same brand will give you maximum performance. And YES, you can confuse both router and adapter. No matter whats brand, you can boost your adapter performance by changing its link speed or duplex to 100M/Full Duplex. This will gives you maximum performance then Auto Function of the Duplex.
Logically its NOT True but Practically I have done it many time.
Jul 15, 2009 | 2wire (1000-400108-001) Router
Slow lan (file transfert) with zyxel ES116P and HP ML150 server
Try forcing the ports that the server connects to on the switch to 100Mb Full duplex, sometimes one side negotiates incorrectly, and the switch can set itself to half duplex, even though the other end is set to full duplex.
Feb 17, 2009 | Computers & Internet
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
try .
Mar 02, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link (R) DIR632 WirelessN 8Port Router Logo
66 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
