Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Kairak prep cooler
I have a kairak pizza prep cooler that has become charged and is shocking people that touch it and another piece of metal. It's giving of ninty volts. Any idea as to what can cause this. Compressor is a year old at most.
  • 700 Answers
There are defrost heaters in this unit also the fan that is on the top plate could be resting in water. put the init into a defrost and after all the ice has melted clear the drain line thats by the fan on top. while your are looking check the wireing to the axiel fan there.
Posted on Jan 10, 2009
3/5 x 3= ? I haven't done math for a long time
If you rewrite it, it should become easier.
3 3
-- x
5
Now, rewrite the 3 as 3
-- x ---
5 1
Now multiply the numerators (numbers on top) and then the numbers on the bottom.
Another way to think of it, is you have a pizza divided into 5 pieces. Two pieces are already eaten. However, you have three pizza like this. How many pizzas do you have. You have 9 slices of 1/5th of a pizza, or 1 full pizza and 4 out of 5 slices on the second pizza.
Good luck.
Paul
Feb 10, 2015 | Office Equipment & Supplies
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib
www.manualslib.com > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Aug 06, 2014 | True TPP-67 Commercial Refrigerator
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
Solenoid opening is noisey
make sure you have the full voltage that is needed. it will be on the name plate.
Apr 19, 2011 | Kairak KAI-KRP72S Prep Table 72""L (2)door...
I have a Randell 5ft Pizza Prep table that's not working correctly and was wondering if someone might be able to help me? The top rail is cooling like it should but the bottom storage area is NOT cooling...
This unit uses Thermostat/Solenoid Valve Combination's to control the temperature
1. Rail 2. Bottom Storage
The way it works is the thermostat senses the need for cooling and energizes the solenoid valve. This allows refrigerant flow which cools the area it is controlling. Once the thermostat is satisfied the contacts open and the solenoid is de-energized closing the valve. If the solenoid is bad, the valve remains closed, no refrigerant flow, warm unit.
Test the solenoid coil (two wires) to see if voltage is present either with a volt meter, or remove the coil off the valve and place a screwdriver (insulated) through the coil hole and you should feel the pull like an electro-magnet (what a coil is).
Dec 05, 2010 | Randell Refrigeration 60'' Refrigerated 2...
PLEASE I NEED YOR HELP KAIRAK COMPANY PHONE #
(800) 833-1106
sample parts list
For parts and manual you gotta go to PARTSTOWN
Tell em Mobi sent ya. LOL
Aug 30, 2010 | Kairak Prep Table 65""L (2)doors HL R ss...
Kairak modle#krp89s condenser fan and comprssor not comin on
It is possible that your main contactor is defective.,This in connected at the compressor motor and can be detached. This is the starter contactor for the motor . Now check the lines of the fan for continuity. If there is voltage coming to the compresor and not working you will check the contactor and then the motor. get help if you are unable but keep this information for getting a good estimate for the work that your technician gives you. Hope you try this out. Good day
Jul 31, 2010 | Kairak KAI-KRP89S Prep Table 89""L (3)door...
Why is there water pooling in my sandwich make up table? My reach in cooler, also?
During the cooling/freezing cycle condensation forms, this drips into a pan and then is evaporated by a heating element.
One of two things could be wrong.....
Your drip pan is clogged
or
your evaporator unit is bad
Hope this helps
Jun 22, 2010 | Randell Refrigeration 111'' Refrigerated 4...
Kairak cold table not getting cool
Clean the condenser
check the fan motor. and the relay.
The place for parts is www.Partstown.com
HERE is the parts list.
Aug 30, 2009 | Kairak KAI-KRP48R Prep Table 48""L...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
91 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
