Insignia 27 heya, i have an Insignia 27" LCD and there is no power, no lights, no nuttin, not even a click when ya plug it in. would it be the ower supply and if so how easy a fix is it? or what will it run to get it fixed professionally? (about) this haopened about 1 month after the warranty ran out PUNKS!!
  • 2,335 Answers
If no lights are visible on the front panel, that means that the power supply has failed and will need to be replace or repair.
You can write to jah2mil@hotmail.com for more info on the repair cost.
Posted on Oct 25, 2008
The screen on my Insignia LCD TV isn't turning on. The red light is lite, so power is getting to it, but the screen is black. Cable guy said it was an esay do-at-home fix. Can you help?
It sounds more like a bad power supply, not enough juice to turn on the screen, I've seen this problem come up in just about every LCD TV out there, very common. Some TV's make a clicking noise while other just don't turn on, I am almost sure it's a bad power supply that just went bad and can't power up the screen at all. Not an easy fix even though you were told It was an easy do it at home fix. Unless you are good at taking apart stuff, you can open the back of the TV and eye ball the power supply unit for a bad blown capacitor or another component that is burned up or melted? Some times you can actually smell a burnt component and sometimes you can't.
Mar 03, 2015 | Insignia "- 37"" Class - LCD - 1080p -...
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
Insignia ns lcd 32 wont power on
When you plug in the set, does the standby light come on? Most likely you are dealing with either a failed power supply or main board. I would start with checked the power supply for bulged capacitors.
Dec 15, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia quit working after storm
Check the fuses on the power supply board first. They usually blow when you get a power surge. You may be able to replace them and get the TV running for a few dollars. If the fuses are good then the power supply board will be the issue. The main board should not be damaged because the surge has to go through the power supply board first.
Aug 22, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
My insignia 52" lcd
Hi.
This is probably a faulty power supply.
Due to the voltages present it is a specialist repair.
Jan 10, 2018 | Insignia Televison & Video
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
27'' LCD panel compatability
Both power supplies are supplying the same voltages to the circuits but in order to use the one from the NS-27LCD 27" you will need to change the wiring configurations to make it work for the LCT2715..
I could repair the power supply from the LCT2715 for under $90.00 including parts, labor and shipping it back to you.
Let me know if you require further assistance.
Mar 01, 2009 | Televison & Video
Insignia 27 inch lcd tv gets no video or audio
the most common item that fails with all LCDs is the power invertor or power supply, and that sounds like what your set is needing is the capacitors have possibly failed on the Invertor
Jun 28, 2008 | Televison & Video
Insignia IS-LCD TV 26 Will not turn on
The power supply will need to be replace or repair if the LCD failed to switch to the blue light.
I repair these power supplies.
Let me know if you need further assistance.
Jun 12, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
