Question about Little Tikes Toys
Little tikes super chef kitchen replacement parts
Faucet, burner, etc.
  • 60 Answers
SOURCE: Parts for Little Tikes Cottage
WIth little tikes items, you may not need the hardware to hold it all together. It all pretty much snaps together. If you do want to use hardware and secure it from wind/etc, you can use any type of common machine screw that you can screw into the plastic.  Let me know if you have any problems.
Posted on Mar 11, 2009
  • 53 Answers
SOURCE: spare parts for little tikes tropical playground
I had the same problem. You can get replacement parts off of their website. They usually don't offer plastic replacement items like slides or stairs. You usually can only get hardware, stickers and wheels and such. For each item they carry replacement parts, their website tells you which part and how much it costs.
Here is the link for your product.
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2490&
Posted on May 04, 2009
  • 53 Answers
SOURCE: where to get parts for little tikes playhouse
Look here. Find your product and it will tell you which replacement parts are available.
If you don't know the name of the item look at the pictures and match it to the best one. If you don't find it, you can call the customer support, but they probablly don't carry anything if not pictured.
http://www.littletikes.com/consumerservice/replacementparts.aspx
If they don't offer any, you'll have to be inventive and come up with something. Take a picture and take it to home depot, lowes or ace. Tell them what your looking for. They should be able to come up with some suggestions.
  • 55 Answers
SOURCE: We need the replacement net for the "Little TIkes"Basketball Hoop
You can purchase replacement nets from Little Tikes.
http://www.littletikes.com/consumerservice/replacementparts-list.aspx?ProductCategory_ID=215
Posted on Jun 30, 2009
slave2aslave
  • 302 Answers
SOURCE: need replacement parts for little tikes kitchen
Try here:
Posted on Sep 23, 2009
I need wheel parts for a little tikes toddler ?? bed
You can visit the website: http://www.littletikes.com/replacement-parent/icat/replacementparent?setpagenum=
All you need to do is enter the product number found on the bottom of the bed and it will pull up any replacement part you might need. If you would like to try an alternate route, there's always other sites such as eBay, Amazon, etc., however, the parts you purchase are not guaranteed to be the exact ones you are looking for and you may lose money. I hope this helps.
Little Tikes Replacement Parts
Apr 29, 2016 | Little Tikes Toys
Manual for Little Tikes Cookin Around Sounds Kitchen
Are you asking for a manual for the little tike's cooking around sound kitchen? If so, you can go to littletikes.com and ask one from them.
Nov 20, 2013 | Little Tikes Electronic Home Cookin Fun...
Water is coming out around the button on top of the pull out spray
if water is coming out on top you need to replace the cartrige. If the button ontop is broken or faulty then the whole handle assembly needs replacement.
The good news is you can replace these parts for free without a receipt. Almost all these faucets carry a lifetime warranty. Simply turn off the water supply at the faucet, then remove faucet and take it to your local plumbing supply store. e.g. Home depot, Lowes, Rona, etc.etc.
Feb 22, 2011 | Hamat 3-2861ST Everest Pull-Out Kitchen...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
I need an instruction manual for Little Tikes Playsmarter Kitchen 600746EU
http://www.google.com/url?sa=t&source=web&cd=61&ved=0CDYQFjAAODw&url=http%3A%2F%2Fdirect.asda.com%2Fon%2Fdemandware.static%2FSites-ASDA-Site%2FSites-ASDA-Library%2Fdefault%2Fv1267458094121%2F707296.pdf&ei=tSzWTO26BYeglAeslOz8CA&usg=AFQjCNFrtwzyp_c5NPey28Hc1Mih2nf-kQ
Oct 18, 2010 | Little Tikes MGA Super Chef Kitchen Set
Burner will not increase when second faucet is turned on
Turn of the hot water valve and turn on a hot water tap in the house. If You have water flow, then you have a problem with a faucet (usually a shower valve). Go to the shower valve and see if you hear water running. If so that is likely the problem. Otherwise there is not enough gas to fire the unit that far and it will fail out. Check the manual most people install these units wrong. If you install it to code then you did it right. If you install it to the manufacturer's specs, you installed it to code and it is right. Then the only adjustment is with a Calibrated CO2 analyzer (instructions in the manual).
Apr 02, 2010 | Bosch AquaStar 250SXO-LP-RE...
Toys Logo
553 people viewed this question
Top Little Tikes Toys Experts
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
