Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Need to replace carriage on stanley sd450 opener how is it done?
When opener tries to open the door the screw vibrates and it sounds as if the part in the carriage that is attached to the drive screw is stripped and the door will not open. The opener will close the door just fine. Also, the door opens and closes properly when it is not connected to the operator.
How do I replace the carriage assembly? The opener is a Stanley SD450 with a date code 96503
Thank you.
Tom
  • laajala May 07, 2009
    Same problem. I haven't unbolted the screw drive section yet, but there seems to be a hard stop near the end which would prevent the carriage from sliding off.
    Problem Solver:
  • 12 Answers
Please make sure you don't have broken springs first and that the door is balanced properly. If so you can replace the "Trolly" by disconnecting the arm from the opener, undoing the opener from the bracket that mounts it to the wall. This usually takes a 1/2 in wrench. Then swing the opener out far enough to slide the trolly off and replace it with a new one. Re-connect everything then re-engage the trolly.
Posted on May 19, 2009
Amazing, I am facing the same problem this morning! The problem is the carraige assembly is stripped. The threads are good enough to push the door dow, but not to lift it. The real concern is that I replaced mine once already 3 years ago and now it is broken again. I am considering a new opener this time because either the door is too heavy for the stanley opener, or it is just a poor design.
Replacing it is easy, you just unbolt the screw drive section and slide the old off and the new on. The part isn't cheap. There are several places that have it on-line for $35. It is part number 49223.
Good luck.
Posted on Oct 25, 2008
  • William Freigruber Oct 07, 2014
    Actually the Stanley design is very good. If the carriage wears out quickly it's an indication that the tensioner springs are not evenly adjusted so that you can open the door easily with one hand.
    New Friend:
  • 25 Answers
This part needs to be made to where the threads are deeper so it can make firm contact with the drive and should be made of harder plastic or steel
Posted on Nov 13, 2012
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
Feb 23, 2015 | Building Materials
How do I put my chain back on a Stanley 8500 Garage door opener?
First you must make sure the sprocket on the garage door opener is spinning clockwise and reaches its limit and stops, you can easily put a pair of pliers between the #1 and #2 terminals on the garage door opener and start the sprocket spinning or just grab a remote and watch from the back of the unit (looking towards garage door ) and make sure it,s direction is clockwise, Once it stops you wanna loosen the chain enough so you can position the carriage which is connected to the chain and with your door closed send the carriage down far enough so that the carriage and the trolley both engage then all you have to do is put the chain over the sprocket and tighten up the tensioner that is located on the trolley...not to tight and not to loose is what you would want in an adjustment !....now since you already ran the sprocket in the down position your door is now ready to test ...when you press your remote or wall station the door will travel up, You have to do it this way , if you don,t ..you can damage the machine or your door ! Good luck and hope I was able to help you with your dilemma!
May 07, 2014 | Stanley Building Materials
I bought a Stanley Screen & storm knob door latch recently (74-8258). The "spindle" connecting the inside and outside handles seems to "float", i.e., not be anchored in place. It seems that with repeated...
If the spindle is installed correctly, "floating" does not hamper proper operation. Review your installation and make sure the floating spindle is properly sated in the handle and alignment is maintained during the tightening process
Sep 03, 2013 | Stanley Hardware 748257 Black Screen &...
The stanley garage door opener Model 3220.51 is about 20 years old. Although there is nothing at the bottom of the door, the door senses that there is something and the door comes back up on its own. The...
If it is a screw drive like mine all I needed to do was lube up the screw with a product called "fluid film" and all was ok. The screw was binding making the sensor think the door was blocked and it would go back up.
Aug 13, 2013 | Stanley Garden
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My stanley deluxe garage door opener suddently stopped. It only makes tik tik sound. What do i do?
You may look at the safety sensors. Try holding the wall button down. If the door operates with the button held down then it is the sensors. Try to align them to look at each other. If not you are probably looking at either replacing the sensors or the logic board. Thanks BB
Jun 30, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener won't work. Motor housing turns partial revolution but looks like transmission jammed. Motor broke from mounting screws. Stanley Premier, came with house, maybe 25 years old. Time for...
THE OLD STANLEY UNITS ARE NOT WORTH FIXING.
PARTS ARE NOT AVAILABLE AND THE UNIT DOES NOT MEET THE SAFETY STANDARDS
TIME TO BUY A NEW CHAMBERLAIN / LIFTMASTER / OR CRAFTSMAN OPENER
GOOD LUCK
May 23, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Apr 01, 2010 | liftmaster Chamberlain Garage Door Opener...
How disassemble?
Open battery covering and (A/V/USB) covering - find a hidden screws there.
Aug 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
1,136 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
