Question about Garden
DISABLE PTO SAFETY JOHN DEERE X320 LAWNMOWER
WANT TO DISABLE SAFETY BACKUP SWITCH
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
  • 78 Answers
SOURCE: My John Deere X320 has gas fires up, but will not
It sound like a service problem. Change fuel filter. If when you pull the line there is gas there but it goes back to the tank.ITS a vent problem. IF no change then the fuel pump could be bad or a possible pickup problem
Posted on Oct 22, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: John deere x320 will not syart. if one coil ground
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Posted on Dec 23, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
Tractor won't start new battery John Deere 4400 does not even turn over
The tractor has a neutral safety switch ,be sure you are in neutral or park , be sure pto is disengaged has a safety switch on pto . Has a operator present switch under seat cushion that is activated when setting in the seat. All these work together to complete circuit to engage starter. Check it out
Jan 10, 2017 | John Deere Garden
John Deere x320 PTO switch not getting power. Mower blades will not engage. Replaced PTO clutch and PTO switch. Have checked seat safety switch and RIO switch as well.
Just out of curiosity check your pigtail that plugs into the pot harness. I have ran into a broken wire inside that pigtail before.
Nov 26, 2016 | John Deere Garden
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
How to replace pto clutch on John Deere x320
Removal and replacement fairly straight forward, you just need to prevent the engine crankshaft from turning. This can done either holding the flywheel or using a piston stop. Also some clutches have a set of flats that a 1-3/8 open end wrench will fit.
When reinstalling the center bolt torque to 50-55 ft-lbs. Also make sure the anti-rotation device is engage into clutch assembly or it will rip the wires out at the first startup.
Apr 07, 2015 | John Deere Garden
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John Deere 314 garden tractor PTO mower deck kills engine
bypass the safety switch on the seat to test that one
Aug 13, 2012 | Garden
John deere x320 will not syart. if one coil ground is disconnected it will start right up. if started this wsy the pto will not engaage.
Jul 02, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
684 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
