Question about Cadet Manufacturing C152 Com-Pak Plus Heater
Manual Reset Switch for Cadet Model RM162 Wall Heater
  • jason cox
    jason cox Feb 12, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Cadet In-Wall Heater - Red Light is on
means that the element is ON
Posted on Jan 10, 2008
SOURCE: Can you tell me where
To find replacement knobs, please try any of the following online solutions:
http://www.reliableparts.com/catalog/Cadet-Repair-Parts-Accessories-466898
http://www.cadetelectricheat.com/heateraccessories.html
Hope this is helpful -
Cadet
Director of Marketing
lsteele@cadetco.com
Posted on Jan 24, 2011
Electric heater wiring
One leg is hot all the time. The second leg switches through a contactor or sequencer & goes through a high temp limit. Each element is wire this way.
Dec 10, 2013 | Cadet RM162 N/A Register Plus 1600 Watt...
I have a cadet heater not working. When I try to push the reset button it does not seem to go in at all. Do I need to replace the complete heater unit or could it be the thermostat?
I had this same problem, which required a new heater. The thermostat tested fine. A bypass of the thermostat switch was attempted and the unit still would not work. The reset switch had never tripped to indicate a problem.
Nov 10, 2010 | Cadet Manufacturing C152 Com-Pak Plus...
Heater stopped working after my daughter was standing in front of it. instructions said to cut power, hit reset button, not didnt work
heaters have a diode inside and it must of triggered it and perhaps blew it out if the reset doesnt work after a couple more times put it in the coll and see if it after over nigth set out will work the nest day keep me posted
Jan 25, 2010 | Cadet Manufacturing CADET SL Series Small...
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Sep 11, 2008 | Heating & Cooling
Cadet heater quite working
that round metal thing is called a klixon overload. look on the side of it and an amperage range should be there. replace the unit and the element should work unless the element itself is blown. check for continuity across the element with your meter with the wires disconnected.
Nov 03, 2007 | Heating & Cooling
Cadet Manufacturing C152 Com-Pak  Plus Heater Logo
699 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
