Question about Lexmark T632 Laser Printer
Change Tray 1 plain legal - Lexmark T632 Laser Printer
SOURCE: Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Posted on Sep 22, 2008
dlindsey74
  • 7 Answers
SOURCE: WON'T PRINT
There is a Paper Menu option somewhere in the menus on the op-panel. You need to go to the Paper Type option and change the Paper Type for Tray 1 to plain paper. You can also hit the Select button when you get this message and you will print.
Posted on Mar 01, 2009
  • 320 Answers
SOURCE: problem with a T630 Lexmark the message "Change Tray 1 Plain Lett
i take it that the printer does not go to ready? does you printer stop with 64mb in the display? if it does change the network card. if this isnt the problem some more info would be great
Posted on Dec 07, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: get the error message change tray to plain letter
    Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
    Posted on Apr 08, 2010
    • 320 Answers
    SOURCE: change tray 1 to plain paper universal
    print the network page to verify the printer is reporting the wrong size paper. this page is outlined by a box if it prints smaller than tne page or the bottom line of the box is missing you will know for sure.
    pull the drawer out and see how many fingers are sticking out of the paper size snap in plate it should be the bottom 2 for letter.
    if this is right there is a paper size pcb on the left side behind the logic pack replace it.
    Posted on Jul 11, 2010
    How to change tray 1 to plain paper legal of T644
    ...Tray Tab. Change the Paper Source to Tray 1. Click the Paper Tab. Select in paper size, Letter. Select for Output Size, Same as
    Sep 24, 2011 | Lexmark T644 Laser Printer
    I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
    You will need to change your paper handling.
    From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
    Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
    I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
    Nov 16, 2010 | Lexmark T630 Laser Printer
    I need tray 2 to be the default setting for this printer. It always reverts back to tray 1 everytime I try to print.
    Paper Handling Issue -
    Hit Menu
    Arrow down to Paper Handling and hit the green check
    hit the green arrow to go into Tray 1 size - arrow down to envlope #10 hit the green arrow to save
    arrow down
    hit the green arrow to go into Tray 1 type - arrow down to envlope hit the green arrow to save
    arrow down
    hit the green arrow to go into Tray 2 size - arrow down to letter/legal (depends on what your using) hit the green arrow to save
    arrow down
    hit the green arrow to go into Tray 2 type - arrow down to plain (assume that your using plain paper) hit the green arrow to save
    also pull out the paper tray and confirm the guides (where you can adjust from letter to legal etc)
    is set correctly.
    That should take care of it unless the document you are tring to print is a different type of paper size.
    Oct 19, 2010 | HP LaserJet P3005n Printer
    HP Laserjet 2430n printer won't see the paper in Tray 2. Continues to give in display paper size *letter and *plain but I set it and it just comes back asking again. When you print it won't pickup from...
    Yes I checked the tray throughly. I also changed to paper to legal plain and changed the configuration...still came back on the display panel change paper size...just won't stop asking.
    If I put the add-on paper tray 500 sheet that tray works fine.
    I was thinking though I might order another paper tray and try it since I replaced the pickup assy and still have problems...what do you think
    I also cold reset the printer just in the event something was set wrong...still has problems
    Oct 15, 2010 | HP LaserJet 2430tn Printer
    Everytime we print we get a beeping sound and an error message that says Change Tray 1 Plain Letter. If we press select, it will print
    In the printer setup menu. You need to change the paper type for tray 1. It's likely set to a different type of paper (maybe card stock?).
    The printer driver will specify what type of paper is being used, and the printer doesn't know what type of paper is in it other than what it is told, so a conflict occurs.
    Oct 13, 2009 | Dell M5200n Laser Printer
    Minolta Magic Color 2300dl printer won't print legal size documen
    Is tray one the bypass tray or a tray. check which one is tray 1
    Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
    Wont print on card stock, legal paper- keeps jamming
    Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
    instead of MP Tray type do the same for Cassette if you desire....
    Best, danakadan
    Oct 11, 2008 | Kyocera FS-1030D Laser Printer
    Paper Tray Settings
    You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
    Go in to the utility menu and you can find this in the paper tray settings area I believe.
    You can turn this off completely to avoid this in the future.
    If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
    May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
    Tray output
    You should configure TRAY 1 as Legal only.
    and Tray 2 as plain letter.
    Specially when you specify from what tray/paper type to print.
    This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
    Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    Lexmark T632 Laser Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
