Question about Epson Stylus CX5400 All-In-One InkJet Printer
My Epson Stylus CX5400 won't print.
I changed the black ink cartridge and now the printer doesn't print anything.
  • Debs
    Debs May 11, 2010
    did you use an epson ink cartridge?
  • 27 Answers
Hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Posted on Nov 08, 2008
I changed the black ink cartridge and now it no longer prints using black ink.
please have at least 2 set of black ink cartridge to determine the problem where in print head area or ink cartridge itself. if two black ink cartridge inserted and still same problem you can now focus problem with the print head. change as possible.
Mar 31, 2010 | Epson Stylus CX5400 All-In-One InkJet...
My magenta ink is out and the printer is showing error. Is there a way I can still print with my black and white cartridge.
in the epson cx5400 you can not still print pecause the printer sign red light on the ink the printer design stop from the factory for this now you change the all set not only magenta that is better because the printer make clean when you change and that take charge from the set ink I think you understand what I mean thank you
basher66
Dec 01, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
I have an epson stylus PHOTO RX500. I need to change the "black" ink cartridge but the ink carriage will not move into a position that will allow the top of the ink carriage to be lifted. When I push the...
Try unplugging the unit and then plugging it back in. When you first power it up, it should do an initial system check, which involves moving the print head. Unplug the unit the moment the print head is in a position to change the cartridge. I did this with my old Canon when I had the same problem and it worked. Hope it works for you too.
Feb 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printer only prints blank pages epson sylus cx5400
Sorry to say, but you may want to read this thread......
http://www.fixyourownprinter.com/forums/inkjet/29681
Jul 12, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Jan 04, 2008 | Epson Stylus 680 InkJet Color Printer
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Printing in black only
Are you using genuine Epson ink? Is it under a year old/ If so you have a warranty repair. Make sure you peeled off the tape from inks. Run a cleaning cycle. If still no color, you may need printheads. Not worth repairing.
Apr 08, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
301 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
