Question about IBM ThinkPad T42p PC Notebook
Ibm thinkpad error 0271 and 0176
When i switch on the pc, after a while, two error message are coming. 1. error 0271 2. error 0176 and then the screen automatocally switch to "a page" with a locker and asking for a password. i have already changed the internal battery but the problerm remains. what shall i do next? Thank you in advance for your help
sands2499
  • 18 Answers
SOURCE: IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Utility to reset the time and date.
Posted on Jul 18, 2008
  • 177 Answers
SOURCE: trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
Posted on Nov 25, 2008
  • 848 Answers
SOURCE: bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Posted on Feb 03, 2009
  • 101 Answers
SOURCE: I CANNOT BOOT MY IBM THINKPAD 2367..HELP
Both errors are related to the backup battery which is located under the main battery. It is probably dead. You can get one on eBay for $3.29 w/free shipping or pay a shop $20 to put one in. If you do it yourself be very gentle plugging it into the tricky little slot - it is possible to break the connector loose from the motherboard but it is an easy repair if you have patience and dexterity. As for the password, try just hitting enter. It is the supervisor password to change the BIOS settings and was probably never set.
Hope this helps.
Jon
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: error no 0176
Change the bios battery.Remove the notebook battery and then you should see the bios battery.Maybe you should have to disassembly the complete pc because it is a little dificult without disassembly.
Fan error on ibm thinkpad
take it to the technician remove the fan clean the dust then put it again if its not working then change the fan
Sep 04, 2009 | IBM ThinkPad G41 Notebook
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Thermal Sensing error
"Thermal sensor error" just means "Broken fan".
Jan 11, 2009 | IBM ThinkPad R40 2681
My ibm think pad has a error message and when it turn on that is all that comes up
I've seen this once before, except there was an error code 225 that went with the hand. turned out to be an unsupported or bad memory chip. There should be on board memory on your model try taking out the memory and starting it.
May 04, 2008 | IBM ThinkPad 600E 2645 Notebook
Laptop problem
1 long beep + 2 short beeps during a POST (Power-On Self Test) for a IBM ThinkPad stands for System board, video adapter or LCD assembly failure.
Dec 27, 2007 | IBM ThinkPad T30 2366 Notebook
Connecting to my home wireless
Does it find a signal? do you get an error message? if so what is that message. if it does not find a wireless signal do you have the the wireless turned on most of the IBM thinkpad has a switch on the side of the computer to turn the wireless connection on and off. make sure it is on. please answer the 2 question above for more help
Dec 13, 2007 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42p PC Notebook Logo
207 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
