Question about LG MZ-42PZ14 42 in. Plasma Television
B/w picture on all av inputs internal tuner from av box colour picture from internal tuner via scarts to video recorder tv on screen menus in colour teletext via internal tuner av box.
    President:
  • 3,130 Answers
Sounds like this set is in the UK??? or somewhere out of the states. If it working good on the tuner or telex box , the equipment your plugging into the AV inputs are not compadible to the tv set or there is a setting in the TV menu to change the format to pal
Posted on Aug 13, 2006
Where can I buy a digital tv tuner to replace the analog tuner in a DVDRHD04
Generally recording machines fitted with an analogue tuner can only continue to be used to record digital tv by using a digital set-top box.
It would not be practical or economic to remove the internal analogue tuner and replace it with a digital tuner unless the person is a highly skilled and experienced repairer.
Digital set-top boxes are available from all sorts of outlets at all sorts of prices. Many surplus boxes can be found at boot sales, garage or yard sales or charity shops at very low prices.
Most boxes have the minimum of connections and often offer only a scart output but some of the older, more expensive and usually better quality boxes also contained a UHF tuner in a similar way to the old vhs recorders so even older tv sets could be used with digital even though no scart input was fitted.
Dec 03, 2015 | iLO DVDRH04 DVD Recorder
Panasonic DMR-E55 DVD Recorder plays does not record
Are you trying to record from a broadcast signal, or via one of the SCART inputs? The E55 has an analogue tuner. If the TV companies in your part of the world have switched to digital broadcasting, the E55 can ONLY be used to record via the SCART and other video inputs, the tuner won't receive anything
Dec 18, 2014 | Panasonic DMR-E55 DVD Recorder
Dvdr3320v will this model record digital tv programs
This device has 2 composite AV, 1 S-Video, 1 Firewire, 1 RF video inputs. The RF input is a way for it to accept a signal from say a VCR's or Video Game's output on Ch 3 or 4.
Your device also can record via internal tuner.. The tuner can tune VHF:2-13, Cable:1-125 and UHF:14-69. Unfortunately, if you only have a UHF / VHF antenna on your house for TV (do not have cable TV, satellite TV, or the like) you're not going to be able to find anything due to the change from analog TV to digital TV. For this, you would need to purchase a digital TV converter box, and put the output of it into the the DVDR3320V.
I hope this helps and good luck. Please rate my reply. Thanks.
May 06, 2011 | Philips Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
I can't seem to get it to record any shows off my t.v.
the hdmi connections are input only.
if the tv has scart sockets on the back, and the recorder also, connect to these. the tv's scart needs to be either 2 way or out put shown with an arrow pointing out of a box for output and a 2way arrow for 2way scart.usually scart socket 2 is 2way. set the recorder as you would normally but set the channel to tye av or scart that you are using. please note that video plus will not work on the scart socket. you may also have to set the output for the scart socket via the menu.
Mar 12, 2010 | Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Just got a new LG 42 " tv have hooked up video and it will play tapes but not able to record for some reason. Scart to Scart connection from vid to AV 1 on tv.
Scart is not always two-way, if that is the way you have hooked it up. A lot of newer appliances have one-way scart connectors, and the vid/av plugs are also wired in one direction.
Are you trying to record from the bult-in tuner to the video? Then you would also have to wire from the av-out of the TV to the video in on the video/dvd... essentially doubling up on the cables.
Jun 09, 2008 | LG Televison & Video
Jvc lt40ds7bj
What model of DVD player do you have? The RF cable jacks on dvd players are only for switching the RF. All players always use AV input/output or Component input/output, the later is the best.
May 12, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
LG MZ-42PZ14 42 in. Plasma Television Logo
303 people viewed this question
Steve Allison
Steve Allison
