Question about Saws
Changing the blade on the Kobalt 10 in sliding compound miter saw
rowdy45176
  • 2176 Answers
SOURCE: change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Posted on Jan 26, 2009
comax
  • 154 Answers
SOURCE: need to replace blade on Superior 10
There is a bolt in the middle of the blade you must loosen and remove it and the blade will come off. THE BOLT IS LEFT HAND THREAD so be careful not to turn it the wrong way or it will break. Superior is out of business so you probabley will not be able to get a new one.
Hope this helps
Posted on Apr 14, 2009
  • 156 Answers
SOURCE: Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Posted on Jul 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: how to change a blade in a sears 10" compound
there should be a spindle lock on this tool, lower the blade guard without removing and hold the spindle lock and the screw is usually left hand thread.
Posted on Sep 01, 2010
  • 520 Answers
SOURCE: My 10" compound miter saw
here is a good place to start looking for a switch.
http://www.ereplacementparts.com/hitachi-c10fce2-compound-miter-saw-parts-c-7927_13297_13298.html
Posted on Jan 06, 2011
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
How do u life up the saw sleeve (the thing u move to cut the wood) on my Kobalt 10-in 15-Amp Sliding Compound Laser Miter Saw
If your saw is completely intact, meaning no missing or damaged parts, the blade guard should rotate out of the way of cutting as the saw head is lowered to make a cut. You didn't give your model number but there should be a push rod or link plate from the pivot point on the base to the blade cover that pushes the guard out of the way as the head is pivotted downward. If you have the cutting head locked down to make sliding cuts the guard should be up and out of the way. If this isn't happening you may have broken or missing parts of the guard system.
Feb 17, 2013 | Saws
User manual for 251946 kobalt sliding compound miter saw
Try to find it on amazon, Amazon com kobalt saw manual, they have great amount of books, so, maybe you are lucky. I hope this helped. Cheers
Dec 02, 2012 | Bosch 12" Compound Miter Saw 3912
Blade stops in middle of cut, slipping motor rpm is un changed. 10" compound sliding Bosch miter saw
Going on the information aas I read it, the blade is slipping, meaning that it is not tightened enough or a spacer in the hole in the blade is too thick. Make sure that the wall plug is pulled out before attempting any work on the blade.
Jan 16, 2011 | Bosch 10" Slide Miter Saw
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
I need manual for kobalt sliding miter saw sm2505lw
Call-18883Kobalt and they should be able to help you. Listen for the prompts to make sure you get the right service agency for miter.
Sep 15, 2010 | Bosch 12" Compound Miter Saw 3912
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
Saws Logo
1,656 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
