Question about Rainbow E series Canister Wet/Dry Vacuum
I want to take the vac apart to clean around the motor ?
E series rainbow how to take apart to clean aroun motor
  • kelly907 Nov 29, 2008
    I have an E Series Rainbow vac that will not start.
    Some place here I thought there was a posting with the same problem, don't know whether a solution was posted for it or not.
    Thanks Kelly
I want to get the motor out from the vacuum.
Posted on Dec 25, 2008
  • 125 Answers
Likely a break in your cord somewhere. if you have a ohm meter check it otherwise tale it to a vac repair shop
Posted on Dec 16, 2008
I'm a Rainbow dealer. Your E Series is covered under warrenty for 4 years on the casing and 8 years on the motor. You should take it to your local Rainbow dealer and have it fixed ^_^
Posted on Dec 29, 2008
Burning smell
The response by Lynnette is in reference to the power nozzle....if you are having this issue with the main unit, then it could be the armature is starting to go bad. Have your Rainbow in front of you and give us a call. We can walk you through some steps to narrow it down.
www.rainvac.com
800-523-0510
Apr 09, 2014 | Rainbow E series Canister Wet/Dry Vacuum
IT WILL NOT START - IT TRIES BUT DOES NOT TURN ON.
Unplug the vac and spin the acorn nut on the separator in the water reservoir. If it spins freely and this vac has run for a few years you may need a fresh set of motor brushes. Do not attempt to run the vac if the motor hums or makes a burning smell. Worn brushes are normal and can often be replaced in an older Rainbow/ Rexair
Sep 28, 2009 | Rainbow E series Canister Wet/Dry Vacuum
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series musty odor
The unit and the nozzle have to be taken apart and cleaned. You almost for sure will need a new HEPA and possibly even the motor cooling filter. There is a lot of dust inside that got moist (moisture in the air,vacuuming wet carpet, maybe you have pets or everything together)
It will require a bit more advanced skills but you do not have to be a vacuum repair professional to do this.
Sep 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Older Rainbow Noisey
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I can't take apart the Rainbow Rainmate to clean it.
The E series has a clear plastic window on each side that you remove to get to the screws, remove them and it will come apart. Some will have tabs instead of screws.
Mar 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
It sounds fine but it is sucking very little
If the suction at the port that the hose hooks into has low suction, then most likely you have a problem with the motor. Some of these Rainbow motors sound ok running, but are running at a slower speed, thus reducing the suction and replacing the motor is the solution.
Dec 24, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
717 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
