Question about Crosley 1950 Pay Phone
Phone cord for Crosley pay phone
My cord on my fake pay phone is all streched out. I can't seem to unscrew the mouthpiece to get at the one end in the hand set. Do I have to find a whole new hand set or is there a way to replace the cord?
  • Crosley Master
  • 2,460 Answers
Try the company website. There's a help tab. http://www.retroshowroom.com/IVG2/N/ProductID-64503.htm
Posted on Mar 29, 2010
How do I fix my mouth piece?
  1. UNSCREW THE PHONE
  2. LOOSEN THE MOUTHPIECE
  3. TAKE IT TO ANY L.G PHONE REPAIR SHOP AND BUY A NEW MOUTHPIECE
  4. FIX IT & ASSEMBLE BACK THE SAME WAY YOU UNSCREWED IT
  5. TEST IT.
Jan 10, 2011 | LG VOYAGER VX10000 Cellular Phone
Why can't anyone hear me talk on the other end?
The reason, no one can hear you on the other end is simply because there is a problem with the mouth piece of your phone.
It must have fallen or hit a hard object so the mouth piece is faulty.
You can use an external earpiece for the time being before you get the mouth piece replaced.
Replacing the mouth piece, you need to get a compatible replacement mouthpiece then unscrew the phone, try to get to the mouth piece and disconnect it from the phone and replace it with the new one you get for it.
Take care and good luck
Oct 08, 2010 | Uniden DCT646-2 Cordless Phone
The person on the other end cannot hear me. i hav to scream at them for them to hear me like thers no mic
this is because the mouthpiece of your phone is defective. its either the mouthpiece is fault and needs replacement or there is dust on the mic hole, blocking it from function.
Use a phone screw driver to open up the phone, clean the mouthpiece hole, use a tiny pin to through dirt or dust that may be blocking the mouthpiece hole. couple the phone back ans try again.
If the problem still persists, then it means you will have to change the mouthpiece entirely. Go to any phone part accessories shop/store within your vicinity, buy a new mouth piece for your phone model, do the replacement and your phone should be perfect again.
Also, before you change the mouthpiece, you still have an option of using a hands-free (earphone) to receive and make calls till you replace the phone's mouthpiece. The hands-free hands-free (earphone) has it own mic/mouthpiece so its definitely going to work.
I hope the above solves your problem. Let me know is you still need further assistance or clarification and I will be glad to respond or reply back to you.
Good Luck
Aug 12, 2010 | LG enV VX9900 Cellular Phone
Motorola Razr in water for about 5 min. dry now
From all indications, everything is functioning fine, just that they can not hear you at the other end.
The problem with your phone is the mouthpiece, the mouthpiece of your phone is bad, that is why they can not hear you at the other end.
All you need to do is change the mouthpiece of your phone and you will see that they can hear you at the other end.
Take care.
Apr 30, 2010 | Motorola Mobility RAZR V3
The person on the other line cannot hear my voice, yet I can hear them clearly. Been going on for a while. I just moved across country a month ago, and the phone, LG Xenon GR500, did this when I first...
The problem with your phone is the mouthpiece,since they can not hear you at the other end, the mouthpiece of your phone is malfunctioning, that is why it works for sometime and not working again now.
Perhaps you might have hit the phone mouthpiece with a hard surface.
All you need to do is to change the mouthpiece of your phone and you will see that they can hear you at the other end.
Take care.
Apr 30, 2010 | LG Xenon GR500 Cell Phone
Phone receiver not working
Is this a replica or a real payphone? Will the transmitter cap unscrew?
A couple of things to try, is take out the transmitter, hold it in the palm of your hand (with the holes in your palm) and slap the assembly on a hard surface. That unpacks the carbon granules.
If that doesn't work, it also may be that a relay is operating because it is want is called a Postpay payphone. Try reversing the Tip and Ring (green and red) line connections and test it again.
Finally, a genuine "g" handset transmitter capsule is about $3, making it cost more to ship than buy. Your picture shows a non "armored" handset cord. If that's really the truth, is the handset black and non-modular? And how does it fit into the payphone housling?
Please don't rate this until you have answers....
Mar 28, 2010 | Crosley 1950 Pay Phone
They can't hear me
this is a mouthpiece problem from your phone.
Loose the phone and read the mouthpiece with a meter. Or clean the phone board where the mouthpiece contacts.
If this does not work, it means you have to change the mouthpiece.
You can use a earphone to receive and make calls for the main time, till you change your mouthpiece.
Best regards.
Feb 18, 2010 | LG Zafiro MG810D Cellular Phone
I can hear the person on the other end, but they can't hear me.
This is mouthpiece problem, i strongly advice you change your mouthpiece.
Meanwhile, for the meantime, i suggest you get earpiece to save you of the stress before you you fix your mouthpiece.
Best regards.
Feb 06, 2010 | LG VX8300 Cellular Phone
Incoming callers cannot hear me very well
Since there is no volume adjustment for outgoing volume with the Navigator key, that's possible.
Go find another handset from another system phone and test it, or just move to another phone and see if they can hear you better.
You could have a bad handset, bad cord (unlikely), bad phone, or bad circuit for that line or call.
Almost al of these items are repairable or replacable.
Carl
Apr 03, 2009 | Panasonic KX-T7730 Corded Phone
Crosley 1950 Pay Phone Logo
114 people viewed this question
Top Crosley Lands Phones Experts
Lisa Demont
Lisa Demont
Level 1 Expert
Are you a Crosley Lands Phone Expert? Answer questions, earn points and help others
