Musicman1429 could you send me the pics of the repair. my email is dkimbro@hotmail.com I am in the process of repairing a viziol30 lcd television. I believe that the mov is going out and anything that could be helpful is appreciated. Thank you.
Protron PLTV 4250- wont turn on-
Had the same problem with one here- The 110v end of the power supply board was found damaged, The following items may need to be replaced:
Fuse F1 (soldered in) . 6.5a @250v time delay
Mouser 576- 021506.3HXP – note this style is for a fuse holder instead of solder in- I added a fuse holder on the board
RT4 & RT5 inrush surge suppressors - I used shintron 8d-18 power suppressing thermistors
BD1bridge rectifier - Mouser 627-D15 XB 60HShindengen
If you want a little more protection modify the board as follows:
1.replace only RT5 in its original location & move RT4 into the other ac input line in front of the bridge rectifier. (cut trace & drill solder holes)
2. Add:MOV (metal oxide varistor) across ac inputs of bridge rectifier. Maida mdc-z481-8oulor D69 ZOV 481 RA 105
This arrangment is copied from a samsung power supply.
Be careful when plugging in the I/O box on the outside cover, if any pins are inadvertantly bend loss of picture will result.
Get a power extension cord and take the TV plug to the power extension cord and relocate to another room and find another outlet.Plug it in and see if it works.If it doesn't,i hope you have warranty:( solutiondoct
Was this helpful?
Yes
No
Popular Solutions for Protron PLTV-4250 42 in. LCD
TV will not stay powered on. Indicator cycles between green/yellow and back to red. Unplugged for 6...
(More)
TV will not stay powered on. Indicator cycles between green/yellow and back to red. Unplugged for 6 hours and tried again. TV would come on for approx 5 minutes, display HD channel then mysteriously power off. TV reacts when pressing power on (sometimes I see blue screen as it tries to power up).
speakers make rattling sound at low volume. Clear sound if volume is increased. Is this a speaker...
(More)
speakers make rattling sound at low volume. Clear sound if volume is increased. Is this a speaker problem or something else? Protron (PLTV-4250)
my Protron is a PLTV-4250, 3 yrs old. For the last couple of days it would just cut off in the...
(More)
my Protron is a PLTV-4250, 3 yrs old. For the last couple of days it would just cut off in the middle of a show, it would cut back on if you waited a little while but now when you cut it on by remote or manually it stays on for 1 second then cuts back off to the red light. The only thing connected to it is a cable DVR box and i've checked all the connections and it's getting power
My tv blinks on and then quickly blinks off. This has never happened before, it was working fine...
(More)
My tv blinks on and then quickly blinks off. This has never happened before, it was working fine this am. Can you help?
