Question about Dell Dimension 2400 PC Desktop
Power Supply diagnosis needed
I've been told to short pin 4 on my pc psu to the case to diagnose a fault. What he didn't tell me is what the result would be. Can you tell me what i'm looking for please? Should it spin the fan on the psu, thus indicating that there's power to it, or should it be to test something else?
  • 903 Answers
It basically resets the bios to default
Posted on Oct 25, 2008
  • Debs
    Debs Nov 01, 2008
    Sorry answered the wrong question on your query.
    It checks your power supply to your computer.
Amber flashing light GX620
LOL... If you haven't already fried your motherboard by using your modified PSU (And that's a big IF), then you need to buy a new PSU with similar specs and connection plugs (ie. a 24pin main) as the original PSU that came with the PC.
May 31, 2012 | Dell Computers & Internet
My Dell NPS 250KB D PSU is dead . Fan is not working at all. My PC didn't start up at all. Main Fuse is alright. Don't see anything damaged physically, no signs of any blown component. How to...
Another thing you can do is smell it.
But I got to tell ya, eBay has a bunch of them, for less than twenty bucks.
I've done it, it ain't worth the trouble. You'd be happier buying one from tigerdirect.com
PLEASE RATE THIS ANSWER
Sep 01, 2011 | Dell 250W POWER SUPPLY NPS-250KB...
Power button on dell 5000 flashing amber
***I'm pretty sure your power supply is dead, you will either #1 take to repair shop or #2 replace it yourself.
The Best Value 550W Gold PSU 12cm 24-Pin 550 PSU is compatible.
The Corsair Memory 550W VX PSU is compatible and Corsair is an excellent brand, but you may have an issue locating the excess power connectors inside the case.
The Xilence XP480-12R Power 480W Quiet PSU would be fine, providiing the "hard drive connectors:2', are 4-pin Molex connectors.
Aug 04, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Plugged my US made PC into a 220v outlet!
Sound to me like all you need is a new power supply. You should be able to find one online.
The power supply should have taken all the jolt and not the motherboard.
If you need help finding a power supply let me know, usually they are pretty generic, but you may have to get one from HP.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 03, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Power supply fan is loud!
Essentially any Standard ATX power supply with a rating of 250 Watts or higher will work
http://www.discountelectronics.com/index.php?l=product_detail&p=1849
Feb 04, 2009 | Dell Dimension 1100 PC Desktop
No power supply to the tower
Be sure that the ATX or BTX power cable (the rectangular cable with 20 or 24 pins) is securely fit into the motherboard. Re-seat it if needed. Also, check the +12V 4-pin adapter (if exists) is seated, just like the 20/24 pin is. If that doesn't solve the problem, be sure that the PSU is switched on and is at 120V (USA) before plugging in the power cable. If that doesn't work, contact the computer manufacturer or the PSU manufacturer (depdending on what you purchased.)
Hope this help!
Robert W.
Jan 09, 2009 | Dell Dimension 8400 PC Desktop
Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Oct 31, 2008 | Tyan S5396A2NRF Dual LGA771 XEON5000 5100...
Replacing a power supply.
You need to connect both 20-pin and 4-pin connector to *********** board. Your 4-pin connector is located between your CPU and a I/O connectors.
If you did it right first time, check if you have anything shorted on your board because your old P/S could go bad for reason.
Good luck!!!
Jun 20, 2008 | EliteGroup K8M800-M2 Motherboard
No power
reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Jan 06, 2008 | Gateway Media Center 610XL PC Desktop
Dell 5100 Dimension - No Power
there are fuses inside psu`s some are solderd and some pop out it i would suggest that u throw the psu away and buy new chances are that it will only cause continues and may even result in
complete mobo failure problems heres a link to a cheap psu   http://www.microdirect.co.uk/(3649)400W-P4AMD-quiet-PSU-with-PFC-20-pin-24-pin.aspx or a more upmarket more powerfull http://www.microdirect.co.uk/(11879)ThermalTake-TR2-500W-Black-Silent-ATX-12V.aspx the choice is yours.
Nov 18, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 2400 PC Desktop Logo
27 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
