Question about RCA 32V430T 32" TV
RCA 32V430T 32" looses color
For no apparent reason, the tv goes from 'color' to black and white. It doesn't usually change back. If you turn the TV off for a while and turn it back on (usually has to be off for a period of time) the color is back. I do not think it has anything to do with "cooling" down. It might just as easily come right back on and since this isn't a "tube" TV. We notice no other changes but this color thing is very inconvenient. The TV hasn't been moved or dropped or anything, however before were given it by my dad he might have had it out in it's original box in freezing weather; maybe even a month or two. The Tv was transported 500 miles. We've had it a year or 2 and this just started though.
  • Anonymous Dec 09, 2007
    We shut our similar RCA off Friday morning and on Saturday when turned on the TV was Black and white and has been ever since.
    Novelist:
    Champion:
  • 275 Answers
Looks like a Cold solder or a EEPROM problem. Get a technician to have a look.
Posted on Aug 14, 2006
    President:
  • 3,130 Answers
This problem could be caused by 1- a bad or dryed out capacitor, 2- a bad video jungle IC, or 3- problem in the eeprom circuit. Its not a repair a consumer can do without the proper equipment and parts. Your going to have to take the set into a repair shop to be diagnoised. Good Luck
Posted on Aug 13, 2006
Konka 32 lcd tv kl32bs22u
RCA ouputs :
locate those colors
RED
YELLOW
WHITE
in a row usually label AUDIO/VIDEO
Aug 10, 2013 | Televison & Video
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Nov 06, 2011 | RCA F32648 32" TV
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Tuning problems
it is due to loose contact near 1 anrena or cable socket. 2 cable wire loose. 3 loose contact near tuner. 4 tuner b+ line or agc line loose. 5 horihontal hold tunning is not proper.or control loose. hope this will help. good luck.
Sep 27, 2007 | RCA 32V550T 32" TV
RCA 32V430T 32" won't turn on!
The fuse is inside the set and is probably ok, but check to be sure. If you have an ohm meter I would check the horizontal output transistor first. It is a big transistor on a heat sink next to the FBT. It has three pins, check the center pin to one of the others, if low the transistor and probably the FBT is bad.
Sep 05, 2007 | RCA 32V430T 32" TV
32 inch rca color
If this is a 32 inch TV then it is a standard picture tube set. If the colors have suddenly gone out of whack, and the set has not been dropped or had any large magnets near it recently, it means that the degaussing thermistor has come loose from its legs. This is very common in the RCA regular picture tube sets. If you look in the back of the set you will see a large black coil of wire wrapped around the edges of the picture tube, with 2 white wires going down to a jack on the main PC board. Right next to that jack is the degaussing thermistor, which looks like a small silver disc, like a nickle, with 2 legs loosely soldered to its sides. One or both of those legs are probably loose, and if you are very careful you can solder those legs back onto the thermistor. If you do not have experience soldering small parts, allow a qualified tech to handle it for you.
Aug 26, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Have you ever had this problem?
Generally,pincushion may be driven by a chip or IC,but pin out is normally a durable xistor. Servicer adjustments are minor for pin correction.Go to pin out circuit & measure voltages.Get back to me on your findings.
Nov 04, 2006 | RCA 32V430T 32" TV
Open Questions:
RCA 32V430T 32" TV Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
