Question about Whirlpool Washing Machines
Whirlpool imperial series A9580XWNO problem
Center upper agitator will not spin in wash cycle
the dr
  • 447 Answers
SOURCE: whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
SOURCE: whirlpool imperial series 2 ultimate care washer
Jewel 42  I had a similar problem with mine, it wouldn't drain or spin.  It was the sensor/lever that lets the machine know that the lid is closed... the screw casing that held it in place had broken... I tied it back in place covered the string with duct tape and now it works fine... or at least it did until the pump cracked this week.
Posted on Feb 28, 2008
  • 236 Answers
SOURCE: My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Posted on Mar 13, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
Whirpool imperial series will agitate but will not do spin cycle
If that is the old belt driven modle I would check the lid switch. If it is bad then no power will get to the wig-wag and the transmission will not be shifted. If the switch is fine check for corrosion on the shift pins or an open wigwag coil. The wig wag has 4 wires. 2 white wires that are common AND 2 other wires for wash and spin. A neat trick is to swap the 2 control wires and see if it washes in spin and spins in wash. That way you can determine if the wig wag coil is bad.
If the washer is a newer model without a belt I would say your lid switch is bad.
Oct 29, 2011 | Whirlpool Washing Machines
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi i have a kenmore washer that makes a loud noise ,it goes though all of it cycles,but the white middle piece barly moves and it won't spin the basket on rinse or spin cycle.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 17, 2009 | Whirlpool CAM2752KQ Top Load Washer
Whirlpool Quiet Wash II center pole doesn't spin.
No. This is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. I hope this helps you.
Oct 04, 2009 | Washing Machines
I have a Kenmore washer 70 series. It runs
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Aug 17, 2009 | Kenmore 20722
Grinding noise during spin cycle/ will not spin
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Aug 04, 2009 | Washing Machines
Kenmore 90 series washer continues to agitate on spin cycle making noise while spinning
Mar 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series washer making humming sound and won't agitate
Mar 04, 2009 | Kenmore Washing Machines
Washing Machines Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
