Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad My keypad is flashing when i log in my code but when i push enter it doesnt work. Is the key pad suppose to flash its lights?
5 Suggested Answers
  • 3197 Answers
SOURCE: remote works randomly,changed batteries now the
Keypad flashing is normal. Sounds like you may have a bad logic board. Try programming everything.
Posted on Dec 07, 2009
swolfinor
  • 504 Answers
SOURCE: Garage Door Key Pad
Have you tried a new battery??
Posted on May 29, 2010
  • 112 Answers
SOURCE: liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Posted on Jun 16, 2010
  • 3197 Answers
SOURCE: Keymaster Remote Pad does not
Try it this way.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Nov 04, 2010
  • 3197 Answers
SOURCE: The liftmaster garage door outdoor
If your other remote units work okay then your keypad has failed.
Posted on Dec 20, 2010
Craftman garage pad doesn't work. When I put in code it just flashes. What do I do to get it to work?
Sounds like, A. Putting in wrong code! B. Battery is bad/going bad! C. The wireless keypad some how been rested.
If A and B isnt it, and C maybe the reason! Here is what you should do.
On the back side of operator possibly behind a plastic light cover or not! You will see a purple, red or gray square button referred to as the "smart button" witch you will need to press and release then enter 4 digit code on pad then press and hold enter till you hear the operator click and in some cases also lights will flash then release the enter button on key pad and it should work....
If you have a external receiver wired to the operator then locate the button on it and repeat same prosse.
If A, B or C doesnt work then its a faulty pad!
Oct 13, 2016 | Building Materials
I have a Genie Directlift 2060 garage opener. My wireless keypad has always worked fine until now. I enter the code and nothing happens. I replaced the battery with the same result. I followed the...
Your wireless keypad may be flashing the red light to falsely assure you that it is working when, in fact, it is not. Another possibility is that the receiver has failed.
Oct 21, 2013 | Sears Craftsman LiftMaster Chamberlain...
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Keymaster Remote Pad does not reprogram The instructions say to type in my code, hold down zero, then press ENTER. The opener lights are supposed to flash but they don't. I've tried proceeding to enter...
Try it this way.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
I programmed 2 new remotes with no issue but, cannot get the remote keypad to reprogram (we just bought the home and don't know the existing code) the model for the garage door opener is Chamberlain...
Your keypad may be bad. If you press and immediately release the smart/learn button and then key in your 4 digit code and press enter the keypad should be working. Be sure you have a good battery. Actually the flashing of the keypad is indicating that it is sending the signal to the receiver. Holding the enter button in doesn't do anything extra.
Nov 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Reprogram key pad for garage door opener
To program the keypad, you will have to press the LEARN button on the back of the garage door opener console and when it begins to flash, enter a new 4 digit code on your keypad and press enter. You should hear a click and see the lights on the opener flash.
Sep 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
27 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
