Question about Garden
Need owners manual for 1991 Murrary riding mower model no. 30550X92 need to level deck
Deck is not level...need to know how to level it.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
The link you listed is inactive please update or add new link for manual murray model 30550X92A
Posted on Oct 17, 2012
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
mowerman1857
  • 389 Answers
SOURCE: 1990 Mastercraft Riding mower manual?
If you want it for the tractor as a whole, I would need the model & serial of the tractor. Look under the seat, or on the frame below the seat or on the platform where the seat mounts. It is usually one of those metalic adhesive stickers with the numbers printed on it. They seem to get knocked off or pulled off quite often but without those numbers, I have no way of looking it up for you.
If yu just need engine information, I can find that with the model and type numbers
Posted on Sep 23, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
How to level the mower deck
There are many possible answers, but the best way I've found and for all types of mowers is:
Put the mower on a level garage floor or pavement area. Rise the mower deck to the highest level. By hand (everything off, of course), position both blade tips to the furthest outside edge of the mower deck (widest from tip to tip). Use two wood blocks or equivalent sized objects and place them under the blade tips. Find something that comes very close to the blade but doesn't touch. This is so you can see a gap for reference sake. Adjust the linkages (usually long links, from front of tractor) until the spacing is the same between both blade tips and the objects under them.
The manual has you measuring the blade tips. I find blocks or spacers easier...
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf - see page 17
May 25, 2016 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
The deck is lower to the ground on the discharge side and drags on the ground when mower deck is lowered. Deck just doesn't look level.
level it out. most all decks are adjustable. look up under the mower and you will see rods or brackets hanging attached to the deck loosen them up and adjust it to the correct position or at least better than dragging.
May 09, 2016 | Garden
I am back hopefully with the correct no.s I need to know how to adjust the deck on a Husqvarna zero turn mower I think it was bought in 2005 or 2006 the owners manual is no help that I can find the model...
This mower deck adjustment is a little tricky. You should be able to find 2 adjusting links on the rear of the deck. The linkage is hinged and you loosen the bolt to drop the deck. On the front of the deck you will find the adjuster pin in the center of the deck. It too is hinged. The adjustment should be: Level from side to side and drop the front of the deck between 1/2 and 1/4". Measure the blade tips not the deck shell.
Mar 29, 2015 | Husqvarna Garden
Video on how to level mower deck on MTD 917.287071 riding mower ?
First the model given is not a MTD it is Craftsman's AYP
There only four adjustments that can be made. Please refer to the owners manual page 21 for the instructions.
Craftsman 917.287071 Owners manual
Nov 15, 2014 | Garden
My deck is cutting unevenly
do a google search for "craftsman mower manual". most likely you can download an owner's manual at the sears, or craftsman, or AYP websites. there will be instructions for leveling the deck in the manual.
generally this occurs after someone works on it to replace a blade or belt. the deck is dropped from the mower, the blades are put back on wrong or the deck is rehung under the mower incorrectly.
you will need to park the thing on a hard level surface, such as a concrete pad. measure the gap between each corner of the deck and the ground. there will be adjustments for each corner and that is where the owner's manual comes in handy. the most frequent cut problem i see is that someone has put the blades back on wrong. the little vanes go UP so as to create a vacuum which stands the grass up for cutting.
Apr 20, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What type oil and what level should I put in my 6-7yr old Murrary riding garden tractor. Model=?, but 25 HP, 2cyl 52 inch deck.
You didn't specify what engine is on your Murray, but most of them were either Briggs & Stratton or Tecumseh. Both of these engine take SAE HD30 weight motor oil. Appoximately 48 ounces will fill these from a complete drain.
If your Murray has an imported engine (honda or kawasaki) then they would use 10W30 oil.
Aug 30, 2010 | Garden
Looking for a parts manual for a Murry Lawn tractor have a (older Scotts brand) mower that was given to us, mows great but need a belt and a deck wheel.
I have a murrary 22" select and The throttle cable has come loose for the handle. I don't know how to put it back on. Can you help me. It's the type that if you turn loose the handle it cuts off automatically.
Jun 24, 2010 | Mtd Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
