Question about Welding Tools
Manual for dayton 6Z935B wire welder
110 volt 85 amp welder
luxur4
  • 92 Answers
SOURCE: i have an old mastercraft 110 volt ac stick welder
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Posted on Oct 09, 2009
SOURCE: lincoln mig welder 180, 230 volt 20 Amp Input.
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Posted on Dec 13, 2009
luxur4
  • 92 Answers
SOURCE: Does anyone know where I can find a how to manual
There a hundreds of books published on the subject, if you live in the USA contact Hobart, lincoln, Esab, all publish books and manuals.
Posted on Jan 27, 2010
SOURCE: ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Posted on Feb 24, 2010
luis_david
  • 407 Answers
SOURCE: have solar 110
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Posted on Jan 02, 2011
Fan runs but nothing else
check small wire on opposite end of Gun. May not be connected well
Nov 17, 2013 | Craftsman 20568N 85 Amp 120 Volt Gasless...
Wire keeps jambing in hose
Make sure you are using a high quality brand of wire. Don't use the junk Harbor Freight sells. Use Hobart or Lincoln Electric. Also make sure your wire feed setting isn't too fast.
Mar 01, 2011 | Clarke Power Products Clarke 130EN...
Clarke 130en Welder settings for Welding aluminum with .030 wire on 1/4" sheet aluminum
try 75 25 argon helium gas or straight helium helium makes metal melt hotter
Dec 11, 2010 | Clarke Power Products Clarke 130EN...
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Welding Tools Logo
408 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
