Question about Toshiba Office Equipment & Supplies
Factory reset toshiba e-studio 230
Machine printed 100K pages, displayed MAINTENANCE. Prints first copies dirty (shadows of was printed before. After couple copies, it prints clean. I want to factory reset it
  • 40 Answers
SOURCE: COPIES ARE COMING OUT WITH A GRAY SHADOW AT BOTTOM
may be drum going to raech life span
Posted on Mar 24, 2010
  • 231 Answers
SOURCE: how is e-studio 230 re
Reset the status counter
(1) The following processes are carried out after completing repair of the cause for the C41 error
message.
(2) Press the [0] and [8] keys simultaneously to turn on the power.
(3) Input 400 using the numeric keys, and press the start key.
(4) Change the displayed status counter from [2] to [0], and press the SET key (Reset C41).
(5) Turn the power on again, and check that it returns to the normal standby mode.
Let me know your result.
Posted on Nov 17, 2010
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-410CN Ink Jet Problem
Please push menu button then start mono then 4x arrow up. Display should be ||maintenance|| and printer should beep. What error code does the display show up?
Posted on Sep 17, 2007
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
ihavsolution
  • 152 Answers
SOURCE: Canon PIXMA1500 prints blank pages
you need to change the print head ...
Posted on Jul 15, 2009
Does toshiba estudio 203 have a memory for past documents
http://www.ebookbay.com/ebook/935/toshiba-e-studio-200l-202l-230-232-280-282-smhh here is the service manual for Toshiba e studio 232/282
Jan 02, 2012 | Toshiba e-Studio 232 Black and White...
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
You can use the Toshiba e-studio 160/200 service manual for this machine,
Enter 08 Service mode and:
check these addresses
340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
250 is 33,000 copies. If set to 0:Nothing displays.
673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
SRU: Service Replaceable Unit.
CRU: Customer Replaceable Unit.
Good Luck
Jun 27, 2011 | Office Equipment & Supplies
Our Toshiba e-studio 352 is leaving a black line down the front of pages that are printed. what is the problem?
If u copy through feeder, then probably is the scanning mirror dirty. If u encounter this problem when printing from pc, then probably is process unit or t/s block problem.
Jun 04, 2010 | Toshiba e-Studio 350 Copier
Our Toshiba e-studio250 copy machine is leaving a
i think you machine lost scuner home positin try to adjust the scuner
Mar 25, 2010 | Toshiba e-Studio 350 Copier
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
Status NG BO
POWER OFF THE MACHINE PRESS 1 3 *(star) together. switch on machine while holding this three sw.
machine will rest.
May 05, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
977 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
